Re: Eleven Rack Grounding? Noise
This is possible. The rack setup is in a room with several computers and a TV. However the issue is reproducible in rooms without. No power poles in my direct area. |
All guitars are humbuckers.
Darryl |
You have touch lamps in the house - the type where you touch them to turn them on and off? Those are HUGE noise generators. |
In regards to the grounding issue on older versions, how do I determine if mine is a previous version with this issue? |
#16
I've got the same problem with my11R ONLY with the Output to Amp outs (both of them).
In my case it has been a ground loop after all. But my unit is simultaneously connected through AES (to a HD rig), the XLR outs (to a mixing desk) and the Out to Amp (to a guitar amp). If you are connecting to a guitar amp try powering the units to different outlets and see what happens. |
#17
1) Is there any chance you're using a speaker cable instead of an instrument cable?
2) Does the hum appear with the guitar's volume turned all the way down? |
#18
Very annoying indeed. I saw you tried a lot of things.
I had a similar problem coming from the PC as WiFi / Bluetooth antenna were near the coils of my guitar when playing. I found 2 solutions : positioning the guitar 45 degree from the PC (not very handy...). As the eleven rack USB cable is quiet long I finally put the PC away .. and get rid of the noise. May I suggest an ultimate test : take the rack and your guitar, leave your home and test it to different places (shop where you bought the unit, friends or relatives house, work and test it ...) Then you will be 100% sure it's coming from your house electric ecosystem, or not ... that's how I discovered that the unit was OK and finally found the guilty antennas ! Hope this help |
#19
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#20
Or try the 11R without the computer hooked up and turned on even if it isn't hooked up. Most computers are not that well shielded.
Eleven Rack white noise issue | Marshall199 | Eleven Rack | 3 | 03-20-2012 07:25 PM |
Weird noise through bass rig/PT? Grounding issue maybe? | Travisx2112 | macOS | 4 | 03-09-2012 01:59 PM |
[SOLVED] Eleven Rack Noise Gate acting buggy | durak28 | Eleven Rack | 1 | 05-24-2011 02:36 AM |
Noise from my brand new Eleven Rack | zuriain | Eleven Rack | 4 | 02-01-2011 11:44 PM |
Eleven Rack- PTLE Popping Noise when loading | buddy5150 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-11-2010 12:12 AM |
