Old 12-05-2017, 10:57 AM
Popmeise's Avatar
Popmeise Popmeise is offline
Default Sample Rate only until 96 kHz (no 192 kHz)
i have installed PT 12.8.2 on my new iMac. But I have two things, I couldn't solve yet:
1. I only can sample until 96 kHz. There is no 192 kHz, if I scroll down. What is the reason? Too less RAM, too less processor (but I have i7), wrong audio-driver?
2. I am missing "Mini Gran", "DB-33", "Structure Free" and few other instruments as plug-in. Am I right to install "Avid Virtual Instruments 10" and others, which are shown here?
Pro Tools 12.5.1
Win 10
Eleven Rack
Asio4All
M-Audio Oxygen 49 mk4
TLM 102
Gibson Classic Rock Marble
AKG K 271 MKII
Old 12-06-2017, 09:03 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Sample Rate only until 96 kHz (no 192 kHz)
Hi, Eleven Rack only works up to a 96k sample rate, which is plenty IMHO.
No, you should install the Air Instruments Bundle 12.0 (and the Air Effects Bundle 12.0) if you're using Pro Tools 12.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 12-07-2017, 03:42 AM
Popmeise's Avatar
Hello Chris,
you made my day. I installed Air Instruments Bundle 12.0 and after that it worked.
For the first point (96 kHz) i got the solution: It was the PT Aggregate I/O- driver, who only is able to go until 96 kHz. When I today took my Steinberg ur22mkII-Interface it was possible upto 192 kHz. This means: It depends on the interface or soundcard, what sample rate is possible.
Pro Tools 12.5.1
Win 10
Eleven Rack
Asio4All
TLM 102
AKG K 271 MKII
Old 12-07-2017, 04:23 AM
Hello Chris,
All that being said what are you recording that needs such a high sample rate? Most home stuff doesn't need those high rates.
Old 12-07-2017, 08:20 PM
cwsand's Avatar
I agree - I still record at 48k in the interest of saving disk space - plus I'd lose some I/O at the higher rates. Of course it's technically better quality at higher sample rates, and some people claim to hear a difference...
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 12-07-2017, 08:21 PM
cwsand's Avatar
Hello Chris,
Glad to help and also glad you found a solution for the SR issue!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Hopefully an easy one for you guys: Opening 8 KHz sample rate / 16 bit sample size sample Pro Tools 11 2 02-24-2016 01:04 PM
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up finalcut Windows 12 02-20-2012 04:00 AM
MBox Micro Sample Max Sample Rate Only 48 kHz? Joe Sciacca 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-07-2008 12:52 PM
Bit Rate/Sample Rate problem? The chipmunks? bspro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2008 05:40 PM
Bit rate & Sample Rate WizDoomBorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-02-2002 12:54 AM
