Re: how to extract tempo from an audio file?
does that answer your question? MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
^^^^He didn't explain it that way... he said he imported a click along with the band stuff...& still, if the band track if there, & they played with a click, then u just follow that which is what I do.. I(just me though) get so annoyed when I go to other studios & the engineer acts like he can't sit down without a tempo so I politely tell them to watch out & I'll do the session...
If u have rhythm.............
He says he has a click and a drum track. Pretty straight ahead. Just identify beat with the audio click track.
Another tip is, if you're identifying a lot of beats: set the nudge to say 1/4.
Once you have a few beats id'd now you can use the + key to move cursor one beat forward where you'll be close to the next transient to id on the beat. Doing this you can stay zoomed in and id accurately. you don't need to make a region break, just have the cursor in place and hit command i. If you find a beat that's way off you know to go back and check the previous id. I prefer doing it by hand because I'm sure it's right. Using beat detictive is too dicey, and by the time I check its work takes just as long and I still don't feel confident. |
same here jguth...
however, Quote:
i also do many "vibe-it" bands with no clic and do every downbeat and often every quarter, and even in a typical 150 bar song almost never more than an hour. b.o.l. e
ihatetyping |
#16
But as far as an engineer not wanting to start without a tempo- I dont agree cuz it makes things WAY easier to be able to be in grid mode, with a grid down to 1/16th or 1/32nds if you need, so you can copy/paste easily with syncopated parts etc. Rather than eyeing it up with a quarter note audio click. If thats what you are referring to. Im not exactly sure Im getting what you are saying tho. But I DEF like to have an accurate grid , i.e. tempo map before I get working cuz its just way easier to move things around, esp when using shuffle mode. Its not about things being robotic, but just a mere faster work flow knowing that I can paste things to a 16th note grid line and know it will line up perfectly in reference to whatever is going on with the imported audio track at that moment. Am I missing what you are saying concerning not really needing a tempo when you have a quarter note audio click? MT
#17
I did this & still do quite frequently if &/or when there is no tempo set in the DAW; I do live sessions all the time where all songs are on 1 long session which is the way we prefer it... U simply group the same way of course, when u wanna place something somewhere, simply hit the down arrow(cursor) @ the starting point & there u have it... it u wanna keep going with it, just let it play after hitting the down, & then when end point comes, hit up & ur regions are now highlighted... But if u(no one in general) don't have rhythm, then yes it would be pretty impossible for that person... I do it & do it accurately 10x's out of 10 & a half... Heck it takes longer of a time waste sitting there watching "engineers" try & figure out what the tempo is so as I said, if I'm not engineering but yet producing the session, or record, I politely say "Let me do it, or let me try som'n real quick"... & its always, "Oh mannn, how did u do that" We haven't had grids always people so thatz why I can't figure out why people think there is no way to do things without it...
#18
I don't even want to argue as I am skilled enough to know what I have achieved in the past and why I got where I got. But show me how you create a sync track to a song that has no steady tempo within 1 hour. The goal would be that at least a 4/4 bassdrum runs in sync for 3 - 4 minutes to such a song. However I did not even reply to the OP as he had a click to sync to but wanted to comment on what Mt.Everest had suggested. Oliver |
#19
and not even worth responding to. Quote:
how powerful this can be in mixing, as well as posting sessions to see the work... but the math isn't tricky; as you prolly know a 4 minute-ish song might contain up to 150 bars. using the system jguth and i described earlier you can do 2-3 a minute (often, when you get in a groove, and know the patterns, you don't even need to listen; just use the visuals) so, that works out to around 50 minutes. throw in a couplea meter changes, maybe the drummer turns the beat around, or the occasional ritard and it's an hour-ish. i only wanted to respond so that any one reading this who hadn't tried this wouldn't be scared off thinking of all the time this must take. once they see the power of being able to cut, copy, paste in a song that had no clic (after elasticizing, natch) or adding samples, loops, or midi and perfectly quantizing those parts if needed... they'd never not do it. best, e
ihatetyping |
#20
OK, smartass.
Once you achieved this within 1 hour I would be happy to hire you on a regular basis so that I do not waste my precious time with stuff like this over and over again. If you are willing to show us what you can do, let us know so that we can measure the time it takes you to show us your magic. ;-) Oliver |
Help - PT 8 - How to extract Midi file | MR290378 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-07-2011 07:20 AM |
Please Help: split a stereo audio track + extract a sample & stretch the tempo. | JamMasterMax | Tips & Tricks | 4 | 04-30-2010 02:18 PM |
Please Help: split a stereo audio track + extract a sample & stretch the tempo. | JamMasterMax | General Discussion | 3 | 04-30-2010 02:11 PM |
my pro tools can't extract audio from M4V video file? | jonboi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-28-2009 01:13 PM |
How to extract audio from .mpg video file? | X-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-05-2002 12:58 AM |
