Reason/PT Trigger problem
Guys
this is such a dumb question, but I just can't seem to figure out whats going on here. I have a Pro Tools session (PT10) with a couple of instantiations of Steve Slate Drums on separate instrument tracks. I also have a third instrument track with Reason inserted as a plug-in and Rewired back into PT. I have a Reason (7) rack running some synth parts that I've recorded into Reason. The problem is I CANNOT stop reason from triggering from within pro tools. Every time i go to just edit some drums, my synths are still playing away from within reason. I've tried everything I can think of with MIDI routing but nothing is working. Will someone PLEASE put me out of my misery!!! Thank You!!! T |
Re: Reason/PT Trigger problem
For now, then, just play back a measure or 2 of the MIDI playing the Reason module and stop and it should stop the note(s). I agree, its as annoying as heck! I also inquired on this over at the Prop-head forums, but no one had a solution there either! Good luck.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
As I understand things you both want to edit MIDI inside PT on non-Reason connected tracks without hearing the audio coming from Reason right? Why not try muting the track in PT that's receiving the Reason audio? Sure the Reason transport will still run but who cares? That's what I do. I just treat the Reason audio coming into PT like any other audio in PT.
Sounds like both Reason and Pro Tools receiving MIDI at the same time.
If using Pro Tools MIDI/Instrument tracks for recording the MIDI parts, Then in Reason, remove MIDI controller from RSN prefs. If that's not an option for workflow, then In reason, the tracks-record auto-engage when selecting tracks. You can deselect Reason/per track record. Then the MIDI thru should disengage. There are a few other items like using the Reason Advanced MIDI as your controller connection instead of the main controller in Prefs. In Pro Tools Prefs choose NONE in the MIDI Tab for Default Thru Instrument.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
click anomalies, using Roland TD-10 to trigger REASON | Jenk2k | MIDI | 4 | 10-24-2007 09:16 AM |
midi and pro tools/reason trigger | psthree | MIDI | 4 | 01-17-2007 06:13 AM |
Anyone using Drumagog to trigger Reason? | uno1234 | Tips & Tricks | 2 | 05-31-2006 06:39 AM |
Using Reason's RedDrum to trigger Fxpansion's BFD | ricfoxx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-28-2004 11:17 AM |
DIGI Midi notes to trigger REASON help !! | syMPh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-11-2002 11:38 PM |
