Faders Off not working
EuControl ReadMe says:
The ability to Suspend Faders/Faders Off has been changed. Previously, pressing Shift + Solo (on strip 1) would turn faders off and they would no longer move in response to automation. This switch combination no longer enables Faders Off mode, because it pre- vented access to Solo while Shift was engaged.However, when pressing the assigned key, it just sets the faders to zero on the Pro Tools Control app and does nothing to the faders on the S3. Is this a bug?
https://lukehoward.com/ |
Re: Faders Off not working
I just tested this and it worked for the S3 and Mix....But I was using PT. I think this only works for PT, what DAW are you using?
I'm on PT 12.8. Might be the interaction with PT Control?
Faders Not Working While Tracking | SteveDans | Pro Tools 12 | 2 | 02-27-2017 10:28 AM |
Disable Faders not working | cshaw | Artist Series | 2 | 05-17-2016 04:13 AM |
Great!!! Faders are working but... | gabrieljay | ICON & C|24 | 4 | 08-28-2009 02:08 AM |
Faders not working on 002 | imace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-15-2008 02:33 PM |
No LED's working just faders | faxbear | ICON & C|24 | 1 | 04-10-2008 05:00 PM |
