"WIN7" is not an audio playback volume.
Guys, I'm new to PT, but I just installed LE 8 and all the updates, so now I have LE 8.0.3 version with the 64 Bit driver. At any rate, when I start a session I get the message in the title.
"WIN7" is not an audio playback volume. Also I get this message as well, "This session is saved on a volume set to Transfer only. If permitted, set the volume in question to P or R in the workspace." blah blah blah. Is it hopeless, should I just install XP on my new PC? System Details ASUS - 2010 Windows 7 Home Premium Intel R Core i5 64 Bit 8GB Installed Ram Terabyte HD Last edited by govols1; 04-04-2010 at 09:22 PM. Reason: Add |
Re: "WIN7" is not an audio playback volume.
OK, I went to the workspace and put the choices on P, I get sound now, but I need to know how to assign the DATA, WIN7, and the PT selections. Thanks in Advance.
I as well as others I would think hav no idea of what u r talkin about...
& I take it that u named ur drive WIN7, otherwise that wouldn't make a lot of sense WELCOME TO THE DUCZ
P is Playback, R is record and T is transfer.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Hey SB is it jus me being confused? I hadn't had my FRUIT SNACKS 2day so maybe I'm reading into the post a bit too much...
IF you are attempting to record to/playback from your SYSTEM drive, you WILL run into problems. Where's your dedicated audio drive???
Stop sayin WIN7, because that is jus a name that u named ur drive...SW asked, "WHERE IS UR DEDICATED AUDIO DRIVE"? Well SW its WIN7 U really shouldn't be recording to that drive because obviously if u named it that, then that probably means that is ur OS drive so that shouldn't really even be in the equation to be honest... PT selections???
"Lacie" not an audio playback volume | FireJoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 08-20-2010 09:19 AM |
8.0.3 giving "not an audio playback volume" error on hot swappable drives only | coolseethie | Pro Tools TDM Systems (Mac) | 24 | 07-09-2010 09:55 AM |
PT 8.0.3 says my ext drives are "not an audio playback volume" | oliarnalds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 02-01-2010 06:49 PM |
After PTLE reinstall my hard drive "is not an audio playback volume" | spudnik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-11-2003 10:36 AM |
Help! "OSX startup is not an audio playback volume" | JLeigh2024 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-30-2003 04:48 PM |
