DIGI 001 with power mac G4
I've got a DIGI 001 and about to get a Power Mac G4 dual 1.0 Mirrored Drive Doors 1gig ram.
Does DIGI 001 works fine with this kind of Mac? Thanks! |
Re: DIGI 001 with power mac G4
Yes ! I have a Quicksilver Duai 1 Ghz and it works great. The Mirrored doors models are noisey I have heard, so try to put it in another room if you can. Cheers Ray 001 Dual 1 GHZ QS 1.5 gig Ram PTLE 6.4 OS 10.3.5 Waves Ver 5 2x TL Audio C1 Presonus Digimax LT Etc... |
Thanks Ray!
I might be wrong,but I heard that DIGI 001 and power mac G4 would only work together in AGP models. Have you heard that? Thanks again! Damiao. |
personal experience..right here...I have found that there is a power supply problem with the Digi 001 and the G4 dual 1 gig mirror door..
I have that set up and it works great until it heats up..if you turn it off and come back to turn it on it will not boot..unless you disconnect the cable from the Digi 001..you can leave the card in..but the cable shuts it down..if you start it up and after it ias up, you plug the cable in it shuts down immediately..I have researched it on the internet and found this to be a common problem..Apple had a swap out for the power supply..not free anymore..it is $150 for the ps..or.. you can buy a digi 002.. but the computer does run it..don't turn it off..I find it must be shut off and unplugged for at least 6 hours.. i'll send you the article..pdf coming to you.. |
so far I did not get this article thanks again Damiao |
Digi oo2 no power | slider3b | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-30-2008 09:07 AM |
Correct Order to Power Up & Power Down Digi 002 Rack? | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-12-2008 06:57 AM |
Power Tab and Digi 001 | gracepoint | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-16-2006 05:48 PM |
Digi 001 & More Power!? | Crabkiller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-31-2002 11:39 AM |
power PC & digi 001 need help!!!! | ms | Pro Tools TDM Systems (Mac) | 0 | 07-15-2000 09:20 AM |
