Blue Screen of death caused by AvidMboxPro.sys
HP Pavilion Slimline s5610y; 596GB Western Digital WDC WD64 00AAKS-65Z7B0 SATA Disk Device (SATA); 8.00GB Dual-Channel DDR3 @ 531MHz
Windows 7 Home Premium 64-bit Avid Mbox Pro 3rd generation Pro Tools 10 -------------------------------- Multiple times a day, while streaming internet video, my PC crashes and I get a blue screen referencing AvidMboxPro.sys. I did try to generate a Sandra report; however, it wouldn't let me. Instead I invite you to view this windows 7 forum post posted by me about this problem : http://www.sevenforums.com/bsod-help...net-video.html Please check out all 3 pages of post, and let me know what you think. Thank you. Code:
Loading Dump File [C:\Windows\Minidump\050116-20092-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available ************* Symbol Path validation summary ************** Response Time (ms) Location Deferred SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols Symbol search path is: SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Personal Built by: 7601.23392.amd64fre.win7sp1_ldr.160317-0600 Machine Name: Kernel base = 0xfffff800`03a08000 PsLoadedModuleList = 0xfffff800`03c4a730 Debug session time: Sun May 1 01:49:07.247 2016 (UTC - 7:00) System Uptime: 0 days 0:56:15.190 Loading Kernel Symbols ............................................................... ................................................................ ...................................... Loading User Symbols Loading unloaded module list ....... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck D1, {fffff88003c9fad0, 2, 0, fffff88007c90420} *** WARNING: Unable to verify timestamp for AvidMboxPro.sys *** ERROR: Module load completed but symbols could not be loaded for AvidMboxPro.sys Probably caused by : AvidMboxPro.sys ( AvidMboxPro+1b420 ) Followup: MachineOwner --------- |
Re: Blue Screen of death caused by AvidMboxPro.sys
You are going to need to complete the Sandra report to get any real help. Without that, we are shooting in the dark. Having said that, I suspect a few things already;
#1-you may have in incompatible firewire controller #2-you only listed a single hard drive(Pro Tools needs a separate drive for sessions) #3-"Dual-Channel DDR3 @ 531MHz" 531Mhz is(to me) really slow and an odd number #4-I would try uninstalling the Mbox driver and downloading/installing fresh I would also check the computer's function without the Mbox driver installed(test it for a day, after you remove the driver) to see if it gives any BSOD without the driver installed. #5-a very quick internet search shows this to be probably not a good computer for Pro Tools due to integrated graphics and a completely unknown chipset(traditionally, the chipset will make or break a Pro Tools computer). If it has a sempron cpu, that's also unsupported. I also see no firewire port, so what model FW card do you have?
Saving Report... File : Computer Report.txt Connection : Local Computer Status Analysing... Finished Successfully : Yes Comments Analysing... Finished Successfully : Yes Computer Overview Sandra report : Analysing... Error (1) : Execution has failed! The module may not be compatible with your computer's current configuration. --------------------- Thanks for the tips. However, my Pro Tools functions fine. This is about the Avid MBox Pro soundcard. I only get the BSOD when streaming internet video, mostly Youtube. Computer crashes. AvidMboxPro.sys is the culprit. By the way, everything has been fine for a year and a half -- just suddenly started getting these BSOD's afew months ago. I will try uninstalling and re-installing. Any other advice? Is ProTools going to update the driver? |
Set Windows to NOT use the Mbox as its default playback device. That avoids any hardware conflicts(both Windows and Pro Tools attempting to use the same hardware). Now you're wondering how you can hear audio from the internet; you have several options:
1-add a set of computer speakers fed by the computer's own audio out. 2-use a monitor/source selector(I use the Presonus Central Station) 3-route the Mbox outs AND the computer audio out into a small mixer(Alto, Behringer, etc). All you need are 2 stereo inputs and even the little $49 mixers at GC will cover that(and most of these cheap mixers are clean and quiet enough these days)
In the Playback Tab in “Sound” – choose Avid Mbox Pro to hear internet audio and choose your computer’s sound (this pic = Conexant) to hear audio in Pro Tools
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! Last edited by unkJE; 07-05-2021 at 12:34 AM. |
jamlab caused my computer to blue screen?? | Matt26 | FireWire & USB Audio Interfaces (Win) | 1 | 11-30-2015 08:06 AM |
Keep getting blue screen of death | Some_of_My_Buses | Windows | 35 | 09-05-2014 03:25 PM |
Blue screen of death *S!@p&***!! | dumdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-23-2007 11:16 AM |
Blue Screen of Death | dadio2002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-26-2004 08:31 AM |
