Old 07-09-2020, 11:31 AM
musicube musicube is offline
Default PT Control automatition parameters not entirely visible
Hi there,
I'm using PT Control v19.5.0.506 with EuControl v19.5.0 in a bigger Setup for Film Music. It's working fine so far only it seems that there are not all automation parameters shown that are configured in my plugin.
I'm using Vienna Ensemble Pro 7 Plugin as an insert and use up to 20 automation parameters, but PT Control only displays 16 maximum.
Because PT Control is only reading the data from the ProTools Session I hope the limitation is caused to preferences, but I simply can't find it. Any help?
See screenshots attached
All the best
Matthias
Old 07-14-2020, 11:56 AM
creativecontrol's Avatar
Default Re: PT Control automatition parameters not entirely visible
Greetings,
The pagetables for plug-ins are always controlled by the 3rd party developer.
I just downloaded a demo of VEP7 and have access to nearly 500 parameters - 20 or so that I mapped to parameters for a single Arturia B3 instrument. So, it seems to be working fine here.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-16-2020, 01:41 AM
Jeff,
thank you for your input, I figured out that my problem was an version issue in 19.5, with your screenshot you showed me that in the recent 20.6 this feature is working fine and so it is in my setup now. Highly appreciated, thank you so much!
All the best
Matthias
Control Plug-In Parameters with a MIDI control surface b1daly Tips & Tricks 8 03-26-2023 09:29 AM
Input Tracks NOT visible on MC Control KeyplayerG Artist Series 3 05-02-2018 08:25 AM
Visible tracks--pref to control edit page ICON interaction? bashville ICON & C|24 2 07-19-2011 07:10 PM
Control VSTi parameters? Led Artist Series 5 03-10-2011 04:55 PM
control plugin parameters and sends with faders on MC Control jacko Artist Series 1 01-03-2011 03:12 AM
