002 dae error 9131 HELPPPPP
So I just wiped my computer and installed os 10.4 and I am now trying to used my external hard drive to have all my sessions on and when I save a session to the ext hard drive and try to record a track it says DAE Error -9131... anyone got any solutions? Do I have to make the drive writable somehow or somthing?? Thanks guys!
+Eric |
Re: 002 dae error 9131 HELPPPPP
Anyone got any solutions?? I looked it up on digidesigns page and all it said was to partition the drive and I have... and still nothing
Hi Eric,
can't be certain it'll solve the problem, -however, look in "Workspace" window(alt > semi-colon), and check if the drive has an "R" in the column after the disk name -if not , change to an "R" ( it may have R, P or T- Record, Playback or Transfer ). If the fault was with the drive, that should fix it , always assuming that the drive in question has been formatted with Disc Utility in OSX ! hope this does it .
www.kitestudio.co.uk Mac Pro Snow Leopard 003 & Midas Venice desk Mindprint DTC Soundelux U99 Drawmer M-Clock |
Im having the same problem...what kind of Ex.Drive do you have? I am uing an Acom Data. I know certain drives have this type of prob...
I had the same problem and found out that I needed to format the drive using Apple Partition Map rather than the DOS format it defaults to under options in Disc Utilities. Sorry, I'm bad at explaining, but I found this solution in a couple other posts on the web and sure enough, that was what fixed it for me. It did require another several hours to re copy my old drive.
Well my drive is a 180gb Pacific Pro Audio Oxford 911 ext drive... and I have it partitioned inhalf and I formated one in dos and one with the osx disk doctor thing to mac... And its record enabled and It doesnt work at all... what can I do???
+E |
anyone????
i've tried formatting different partitions to different formats with no success, it tends to have to be one or the other. I would format the drive in disk utility to Mac Extended Journaled, i've never had a problem using multiple partitions in this format, fat 32 formatted drives will not work full stop with Pro Tools. Kind of odd given that every other mac app does, however the fat 32 format does not allow files to exceed 4GB so maybe thats why they scrubbed it.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
I got the same problem too. Macbook Pro, Digi002 Pro Tools 7.3, External Seagate 400GB drive.
What a pain. Everytime I use Pro Tools I spend more time with system issues than recording. The big downsize of Pro Tools is the incompatibility with most of the computer gear in the market. I wonder if these bugs can be fixed with an update like any other software company does when things don't work. Regards, Tony T. |
DAE ERROR 9131 help | Pedro perez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-12-2006 12:45 AM |
CneoFreeList.cpp ERROR Line 806...HELPPPPP | bangembeats | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-30-2006 04:29 PM |
DAE Error -9131.... Yes, the dreaded -9131. | defconnect5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 08-06-2006 06:54 AM |
Dae Error -9131 | penrithmatt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-11-2005 07:23 PM |
DAE Error 9131 | kil howlie day | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-12-2005 09:30 AM |
