Old 10-16-2020, 04:51 PM
Default Re: Reboot required to see Eleven Rack as an input/output device
Originally Posted by DonaldR View Post
I have an old Macbook pro, around 2010, but still going very well for what I'm using it for. Is it possible that your 11R is always connected to you Macbook? I tried 2-3 sleep/wakeup cycles and it was working if I let it connected. Also 2-3 cycles of start 11R/start Macbook/shutoff 11R/start 11R while still connected. It seems to loose/hang overtime.
So now I'm confused. So the Mac sleeping with the Eleven Rack connected and powered on does not cause the driver to hang for you? ... The Eleven Rack actually works after it wakes up?... as the Playback Engine or with other apps?
Old 10-17-2020, 08:45 AM
DonaldR DonaldR is offline
It's working when sleeping/awaking in the same day. The problem is in the long run, as I said, I'm using my Mac for weeks without closing/rebooting.
Old 10-17-2020, 08:47 AM
I think I will simply get an spdif coaxial/toslink converter and plug my Eleven Rack directly into the Macbook input port.
Eleven Rack - Distorted audio at reboot BIG_brother Eleven Rack 2 08-21-2020 08:05 AM
Required software for Eleven Rack jvining Eleven Rack 10 12-28-2013 01:19 PM
Eleven Rack not recognized after a OS boot or reboot. tengai Eleven Rack 2 02-28-2012 08:39 PM
Pro tools LE plus Eleven Rack. Audio Interface required? needled39 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-15-2010 05:27 PM
Is this possible with Eleven Rack? Recording technique help required... rmpacheco Eleven Rack 13 10-13-2010 11:33 AM
