M-Powered without actually utalising hardware
Ok im really new to this and im sorry if im very slow on the uptake! Is it possible to have the m-powered hardware pluged into the system (so that pro tools runs) but actually use a different bethod of data entry to the software? I want to use a behringer Ada8000 8 mic pre amp with adat out to send the audio via a behringer BCF2000 to the Mac. The entry level m-box does not support adat and only has 2 channels. By using these behringer products it would be possible for me to record 10 channels and send them via USB 2.0. Hope you can clear this up and i apologise again if ive made some huuuge oversite!!!
Re: M-Powered without actually utalising hardware
unfortunately this won't work. you'll have to use one of the supported m-audio hardware interfaces with pro tools m-powered. you could get a firewire 1814. that will work with your ada800 to give you 16 inputs.
Back to basics: Strat, DRRI, and pedals gallore. |
Ok, so if i brought the firewire 1814, id have to buy a copy of pro tools to go woth it. Would this be the LE version or M-powered version, or are they the same things? what are the differences? What is the difference between a full pro tools rig and the LE/M-Powered versions? Thanks again
go to home page and click on Products to see the differences.
ProTools MP only works with the recomended m-audio products like the FW1814.
Be ready to capture the magic... even in your sleep. |
Hardware On M Powered Pro Tools | gnicks18 | Pro Tools M-Powered (Win) | 1 | 10-15-2011 02:19 PM |
what else do I need m-powered 8 (hardware wise) | smackover76 | Pro Tools M-Powered (Win) | 3 | 05-07-2009 01:02 PM |
M-Powered Problems/Hardware being used by another app | bmm4ever | Pro Tools M-Powered (Mac) | 1 | 04-28-2007 08:02 PM |
Hardware required for M-Powered | dave holder | Pro Tools M-Powered (Win) | 1 | 02-05-2007 05:28 AM |
Can I run my m-powered software without hardware? | Flailey | Pro Tools M-Powered (Mac) | 3 | 10-17-2005 09:14 AM |
