Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 04-21-2021, 02:01 AM
windmillaudio windmillaudio is offline
Default ProTools MTRX studio - PT can't play, UA Apollo works fine
I have a MTRX studio as my main interface, and have just formatted a new Mojave install.
Using the HD Native Thunderbolt as the playback engine, ProTools won't play. Stop button lights up and Play button flashes.
If I change the playback engine to my UA Apollo, ProTools plays fine.
I'm running PT 2020.11, and had installed the 2021.3 Avid HD Driver. Tried installing the previous 11.3.2 Avid HD Drive, and neither are working.
Dadman and PT are both set to 48kHz, internal sync.
Anyone seen anything like this?
Old 04-21-2021, 02:24 AM
LDS LDS is offline
Default Re: ProTools MTRX studio - PT can't play, UA Apollo works fine
Oh yes, I have seen that quite a few times.
My only suggestion is to check that the MTRX Studio in DADman is set to adapt to Pro Tools 1/2 (or Digilink 1/2 depending how it is labelled) under the synchronisation settings.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 04-21-2021, 02:37 AM
Solved... I had tried the available HD Drivers from the Avid Site, but there's an HD Driver that comes within the PT installer. I had installed PT 2020.11 off site without the MTRX studio, so had forgotten about the HD Driver.
I then installed the Avid HD Driver 2021.3 once on site, and thus, problems.
Once I installed the matching Avid HD Driver 2020.11 in my case, to match ProTools, everything is working.
ProTools works fine, but audio to everything else is gone satis5d Pro Tools | Intro Discussion 1 02-29-2016 10:28 AM
6.4 works fine, then "Protools needs to close" heatsky2112 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-06-2009 07:21 AM
HELP PT works fine one day and not the next! oddeodude2012 General Discussion 1 03-17-2005 12:02 PM
My 001 works fine, should I go 002? jeronimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 08-17-2004 02:02 AM
ProTools Free Works Fine twas001 Digidesign Hardware & Software 0 11-02-2000 09:53 PM
