help hooking up a sub
I will be buying a sub tomorrow. I have the events 20/20 passive monitors with a ra 100 amp. how would i hook up a sub to these since the l and r are being used. also using a mackie 1402 board.
Re: help hooking up a sub
aeugene,
Since it is already tomorrow, you have probably figured it out. Hopefully, you bought a subwoofer similar to a Tannoy PS110b. If you did, just run the R&L monitor outputs from the digi to the inputs on the sub, then the outputs on the sub to you amp. Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
Another way to do it is to use a "Y" to come out of one of the Mackie Aux Sends and run that into the sub L-R inputs.
You may then use each channel strip's individual aux send pots to control how much signal you're sending to the sub. You may also easily 'dial out' the sub with the Master Aux pot, and so use only your main monitors for editing or comparison. Very slick and versitile that way. |
Hooking up Pre to 192 | moonmusic | Pro Tools TDM Systems (Mac) | 9 | 12-17-2013 06:49 PM |
hooking up my RME ADI-2 | WB1984 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-02-2010 03:55 PM |
Hooking up new pre to 002 | Stoneroses63 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-13-2007 07:58 AM |
Hooking up RNC to RNP | Elvisaintme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-30-2003 10:57 PM |
Hooking up MC-307 to PT anyone? | peneslapepe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-18-2002 11:47 PM |
