Old 05-11-2012, 06:18 AM
aldersyde aldersyde is offline
Unhappy can't see all plugins from edit window
When I am in the edit Window and I go in to my insets to choose a new plug-in, certain ones are cut off at the bottom of my screen.
I have not been successful at fixing this by changing my monitor settings.
If I move Pro Tools to my second monitor, I can see these plugins.
Is there a way to change a setting in Pro Tools so that I can see these plugins?
Old 05-11-2012, 07:15 AM
Default Re: can't see all plugins from edit window
Are your 2 screens different? Just wondering why one would be different from the other. Anyway, in general, any plugin will open with its top at the same place on a screen as the previous plugin(the last one you had open). If some plugins are taller, they may extend below the bottom of the screen, so if you drag any plugin higher on the screen, that would allow taller ones to open in a position that would show more or all of them. Some experimentation might make this a bit clearer
Old 05-11-2012, 07:43 AM
Actually, I was referring to the plug-in list. When the list is big enough to include two columns, the bottom few plug-ins of column one are not visible at the bottom of my screen.
I do have two different brands of monitors for monitor one and two.
Old 05-11-2012, 08:53 AM
I don't know how to close a thread but I solved my problem by downloading the latest drivers for my display card and changing the display settings.
Old 05-11-2012, 09:13 AM
Drew Mazurek's Avatar
Sounds like the native resolution of your monitor isn't being outputted by the vid card.
www.drewmazurek.com
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
dual monitors... edit window + mix window T-Jac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 37 04-23-2010 02:21 PM
Cannot change EDIT MODE in edit window Xavior Pro Tools M-Powered (Mac) 2 05-24-2007 12:51 AM
Maintain key focus in edit window/plugins? cave7audio Tips & Tricks 2 04-06-2005 11:33 AM
How do you scroll the window with the audio on edit window? fsilano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-01-2001 09:53 AM
