PT9 Raydat
Anyone using this under OSX? Would love to hear experiences. I need more IO than what my Apogee Ensemble is providing, this seems perfect, and its PCIe.
Re: PT9 Raydat
The RayDat works great with PT9 and OSX.
Solid as a rock. The mixer app that comes with it works like a charm. I'm very happy with it. Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
Re: PT9 Raydat
are you using totalmix for cue mixes? how is the latency with using pro tools at low buffer settings. what converters are you using?
thanks for the response. |
Re: PT9 Raydat
I'm only using the AES and SPDIF I/O for now. I had to use total mix to get those inputs routed into PT because they are inputs 33-36. My convertors are a HEDD 192 and Benchmarck AD/DA 96K.
I'm running at a buffer of 64. I haven't measured the latency with Total Mix but it's minimal. There might be some figures floating at RME's website on that but mixing through the card provides no noticeable latency. Perhaps some other will chime in. I wanted to go PCie with my setup and I'm really happy I did. Carl
Re: PT9 Raydat
i am very surprised there are not more users. i am struggling to find any info about this card with pro tools. it seems the perfect solution for none HD users wanting all the IO and wanting to use their own converters.
especially since the lightbridge and presonus deal have been discontinued. I too am looking forward to getting off firewire and going pcie. |
Re: PT9 Raydat
Im waiting on delivery of PT9 I'll let you know...
Mac Pro 2 x 3,2 GHz Gainestown - 24 GB RAM - 120GB OCZ Vertex2 SSD - OSX 10.6 - RME RayDAT - RME ADI-8 Pro - UAD-2 Quad - Mackie C4 Pro - BM15A |
Re: PT9 Raydat
I think you'll be happy with it. Carl
Re: PT9 Raydat
you guys using mac? which pcie slot you using? will it essentially eat up two slots, or will it fit directly above the graphics card with the expansion card in the dummy slot?
Re: PT9 Raydat
Im using it with 1 slot. I only need 2 ports.
Re: PT9 Raydat
Using RayDAT with PT9.0.2 OSX 10.6.6 - no problems other than having to perform some routing tricks to use the AES and SPDIF in/outs (33-36). Pro Tools won't access them directly.
I've done cue mixes both with TotalMix and also through PT. Honestly - it is easier through PT - and - at 64 samples playback engine, performers really cannot tell the difference. The biggest problem with the RayDAT - or any lightpipe-based system - is that you need to re-patch your optic lines if you switch from 48k to 96k. -Dan
Pro Tools 2020 | Mac OSX 10.15.x RME Ray-DAT | SSL Alpha-Link AX 2019 Apple Mac Pro 16 core / 96GB |
PT9.0.2 RME RayDat 96kHz freeze | Pz5 | Windows | 6 | 12-22-2015 07:55 AM |
Mac Pro with RME RayDAT UAudio Apollo and Focusrite Octopre | Jim-UK | macOS | 0 | 01-17-2013 03:37 AM |
Anyone currently using RME RAYDAT? | danander11 | General Discussion | 0 | 10-24-2011 10:05 PM |
RayDat Plunge | Carl Lie | macOS | 10 | 02-21-2011 05:08 PM |
Pro Tools Native...Use with Raydat? | ROBB007 | Pro Tools 9 | 3 | 12-21-2010 11:37 AM |
