Old 11-19-2013, 07:21 AM
Alexmc1988 Alexmc1988 is offline
Default Pro Tools 10 trouble on a Hackintosh
My Hackintosh has the following hardware.
Intel 3930k
Gigabyte GA-X79-UD3
Corsair Vengeance 1600 32GB
Radeon HD 5770
My interface is the TC Electronic Konnekt 48.
I have been running OSX 10.8.5 with Pro Tools 10.3.7 for a while now with out any issue. All of a sudden PT doesn't want to open. Even with all of the plugins removed from the plugins folder. In the Activity Monitor PT is (Not Responding) on and off. Eventually PT will open and runs OK but this can take 15-20 mins.
I have done all of the OSX optimizations. I have Turbo Boost, C-State, and Hyper Threading all turned off in the bios. I have reinstalled Pro Tools and tried trashing the Prefs and Databases.
Everything else runs fine. I'm at a loss here. Any suggestions? Any more info needed?
Thanks,
Alex
Old 11-20-2013, 09:58 AM
Default Re: Pro Tools 10 trouble on a Hackintosh
Another fresh OS install. The only other thing I have installed is Pro Tools. No third party plugins or anything. Its still doing it. PT takes about 15 mins to open. In activity monitor it comes in and out of Not Responding. It doesn't create a crash report unless I force quit. Even then it doesn't say any threads have crash.
Any advice? Everything works fine on the Windows side. I might have to just go back to that.
Old 11-20-2013, 04:21 PM
mmk mmk is offline
it may be your interface, or the audio driver it is defaulting to when opening pro tools. check that. your computer should work
Old 11-21-2013, 10:41 AM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
Make sure your ethernet interface is addressed as eth0 ... do a search on tonymac ...
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Old 11-21-2013, 11:43 AM
Thanks,
I have tried 2 different interfaces. An MR816 and the Konnekt 48. Same result.
Wombat, I have the ethernet disabled in the bios. I have a wireless card installed but even with wifi turned off it doesn't make any difference. Actually I tried removing the wifi card completely.
I have also tried different firewire cables on both interfaces.
Old 11-21-2013, 12:15 PM
YYR123's Avatar
YYR123 YYR123 is offline
I would run 10.8.4 personally
Daniel
Old 11-21-2013, 12:25 PM
thanks,
I am getting ready to jump back to Snow Leopard. I might see if I can download 10.8.4 after that.
Old 11-21-2013, 01:44 PM
YYR123's Avatar
thanks,
Yeah - the only reason I left snow leopard is b/c I wanted to resize a finder window on any side !!!
Daniel
Old 11-21-2013, 09:58 PM
Well, I have snow leopard 10.6.8 installed and its doing the exact same thing. It takes a couple mins for the splash screen to even come up. When it finally starts loading things to runs through the stock plugins pretty quick. When it reaches my McDsp AAX plugins it hangs on every single one of them. I would think it was an iLok issues(and it may still be) but it worked fine on my windows partition. I had to use the VoodooTSCSync.kext To get it to boot. Thats the only other thing I did other than easybeast. Any suggestions? Maybe bios settings?
Hackintosh for Pro Tools 7 - 7.4 anybody ? zavid Pro Tools TDM Systems (Mac) 0 02-19-2014 03:51 PM
Hackintosh with Pro Tools? jakedavis Pro Tools 10 266 12-03-2013 09:28 PM
Hackintosh with Pro Tools HD 2 fatcode Buy & Sell 0 10-18-2012 05:23 PM
Hackintosh on my rig? Raoul23 Pro Tools TDM Systems (Win) 7 07-01-2011 03:26 PM
Hackintosh Help HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-16-2010 10:45 AM
