Amplitube question
Is there a way to record a guitar track w/the amplitube plugin. Then remove the plugin and it play back the track w/ the plugs sound??
-Sony Vaio RX-860 - P4 2.4ghz, 1.5gb ram -Sony Vaio PCG-K23 - P4 2.8ghz, 960mb ram -XP home w/service pack 2 - Digi 002R - PT 7.1 |
Re: Amplitube question
Sorry man....someone will correct me if I am wrong but, that is what the plug in is for....it needs to be plugged in to work the sound, if you take it off no amp....does that make sense?
Hp 819n 2 seagate sata 7200 200/160gig 1.5gig ddr2 pc3200 ram pro tools 6.9le m-box All you need is a bag and a sleepin bag mat |
I suppose you could bounce the track to disk and reimport it as a wav file. But why?
Macbook Pro i7, 17". Dell P-650, Mackie 1402/HR824/SR1530, 002R, TLM 103, Beyer TG-X60, SM58, AKG 112/C418's/C419, TPS II, Kurzweil ME-1, DM-Pro, Pod-XT, Fender Blues Jr. |
You can use it on an aux track and bus it to an audio track.
I do something similar, but I use two audio tracks: one records the direct guitar (so I can change the tone later if I want), and one gets the bussed output of whatever modeling plugin I'm using.
I am kinda disapointed that if I record w/ the amplitube, that the playback will only have the amplitube sound if the plugin remains on the insert. (lame) (So everybody understands what i am doing: guitar direct-->preamp-->digi002 w/ amplitube on the track while recording)
From my post above:
guitar direct-->preamp-->aux track w/ amplitube on the track-->bus-->audio track with bus as input or in my case: guitar direct-->preamp-->audio track for DI w/ amplitube on the track-->bus-->audio track with bus as input
Cool, I'll try that.
Thanks.
Well, I'm into that.
I have POD XT and Amplitube. I would like to try that as well. Should i get DI Box? What is a good DI Box. We used to record guitar to tape and send signal to amp from tape's direct out and hear that back while playing. Then, only the guitar used to get recorded. This way, you could re-tone the amp if it does not sit right in the mix. Have you guys ever tried that?
Yavuz AKYAZICI Guitar Player, Composer http://cdbaby.com/cd/volcano http://volcanojazz.com http://myspace.com/volcanojazz |
Yes it is cool just to send it to another audio track using any stereo out except 1 and 2. I think you would have to disable your other tracks to do that. That way you can save your original track dry. You can also bounce to disc and import to another track0 I do that a lot too. In my limited experience, I generally dont want to run Amplitube on more than two tracks at the same time. I also save settings or just put some notes into the comments section on the mix window.
Amplitube question | sabatooch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-11-2010 03:30 PM |
Amplitube in PT question | Friend | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-19-2008 07:43 AM |
Amplitube question | jonah day | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-01-2005 03:26 PM |
Amplitube and TRacks question | myronfuller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-01-2004 10:14 AM |
Amplitube question | Superclock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-13-2003 04:38 PM |
