Session load stuck at "activating inserts"
Hey all...
I have a certain session that won't finish loading. It will generally get about halfway through the progress bar and inevitably get stuck at "activating inserts" on one track or another (snare top, bass, etc.) I've tried opening other sessions and they're totally fine. I also tried going back to a very recent session file back up of the problem file and it's getting stuck the same way. I just trashed prefs, restarted and reloaded and am getting the same thing. All of my tricks are used up. Any experience with this out there? thanks, jim PT 8 Mac 8-core 10.5.6 4GB RAM |
Re: Session load stuck at "activating inserts"
Try opening a new session and using "import session data" from the file menu to bring in each track individually. It should allow you to zone in on where the problem lies.
+1 for this solution...
Studio: Mac Mini 2.6 GHz i7 16GB RAM PT 2019 and 10.14 UA Apollo Quad Outboard: 2 x Summit Audio 2BA-221>TLA 50>EQF-100 2 x dbx 165a 4 x Shadow Hills GAMAhttp://humpbackmedia.net[/SIZE] |
Good advice above. You could also try holding the shift key while opening the session. This will disable all inserts so the session may open. Then you can go thru and see if you have a bad plugin or maybe a missing plugin. At the very least, if you can open the session this way, you could consolidate all the audio tracks, which might make it easier to import the audio into a new session.
great thoughts...thanks. I have tried importing session data, but the same exact thing occurs. I will try holding shift. Great call...
so it loaded successfully holding down shift. What would the process be like to find the issue with the inserts? I've been opening this session every day for the past two weeks with no problems...weird.
Once you know you can open it, what I did was to Make Active all the inserts in the first slot>save>close> and try to open it(without holding SHIFT). If it opens, you know all the plugins in the first slot are okay(and move on to the next slot). If it does not open, then you know some plugin in the first slot is corrupt or outdated or otherwise kaput. Keep working at it and you will be able to narrow it down to what plugin(s) are whacked. Once you figure out which, you can uninstall or update as needed. If you navigate to the Digidesign/DAE folder, you will find 2 sub folders, one called Plugins and the other called Plugins(unused). Each plugin will have 2 files(with different file extensions). You can drag the 2 files for any offending plugin from the Plugins folder, to the Plugins(unused) folder(or anywhere you want) and Pro Tools will not load those plugins.
PT 9 spends ages on "activating inserts", when loading a session | Talisker | macOS | 1 | 06-23-2012 04:52 AM |
pro tools 8 stuck at "structure" at initial load | Awesomeworld | General Discussion | 8 | 09-21-2011 01:10 PM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
PT 6 breaks S/PDIF "out" and "inserts" on I/O setup | wcody | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-04-2003 05:14 PM |
002 Bug - System Displays "Working",002 doesn't load session | OneMadSon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-02-2003 06:09 PM |
