Old 02-13-2014, 04:12 PM
ksgltd ksgltd is offline
Default PT11HD on 2011 MacBook Pro
Hi All,
After searching the web high and low I can't seem to find a convincing answer to my question, which is…
Can I run PT11HD (software) on a MacBook Pro 2011?
I currently have PT10 and CPTK2. I did look at upgrading to PT10HD last year but I never got around to it. Now the only option available at the Avid shop is an upgrade to PT11HD.
Does anyone have any experience with PT11HD on a MBP 2011? I know the Avid website does not list it as a supported computer for use with PT11HD
Does any one have any ideas? I know there were some others on this forum looking for an answer but there was none forthcoming.
Thanks in advance!
Old 02-13-2014, 05:29 PM
Southsidemusic's Avatar
Default Re: PT11HD on 2011 MacBook Pro
Hi
I would not think there would be any issues as long as you have minimum 8GB RAM and a dedicated 7200rpm harddrive for recording to. No green or blue power saving drive and HAVE to be USB3 or Thunderbolt or FW. NO USB2 drive casings. If your computer is up to scratch I don't see any problems with it, also in the PT11HD upgrade you will get both 10 and 11 HD so you can have them both on the same harddrive.
If it is a core duo I would be causious but it might work for some. What interface are you going to use and what OSX version?
Best Regards and Welcome to the Community
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 02-14-2014, 01:55 AM
Hi Christopher,
Thanks for your reply. I have a 8gb Ram and dual internal SSD. I was planning to use an RME MADI-Face.
I would only be tracking with this machine. No serious editing or production.
Worth a try?
Thanks.
Old 02-14-2014, 04:41 AM
twdwyer twdwyer is offline
I run PT HD Native on an early 2011 MBP 17" with a Magma Thunderbolt chassis, no problems whatsoever. I have 8gb ram and an internal ssd drive for the system, use FW800 drives for audio. It's a great setup.
Old 02-15-2014, 01:05 AM
JFreak's Avatar
JFreak JFreak is online now
PT11.1.2HD working perfectly here on late 2013 top-of-the-line MBP (16GB memory, 1TB storage). Zero problems so far, using OSX 10.9.1
Janne
Old 02-15-2014, 01:19 AM
Originally Posted by ksgltd View Post
Hi Christopher,
Worth a try?
Thanks.
Hey
Most definately worth a try
Looks good so All The Best of Luck to You
Let us know how you get on with the system
Best Regards
Christopher
Best Regards
Christopher
WEBHOME
Old 02-16-2014, 11:04 AM
info@npp.co.uk info@npp.co.uk is offline
I have just put together a PT 11 HDX 2 rig using a Magma Roben-3TS to use with my mid 2012 MacBook Pro Retina 16GB. It is so good that it's blowing a Mac Pro HDX system I'm using out of the water. SSDs everywhere. I was thinking of getting a new Mac Pro but this system is just incredible. I have Logic running with loads of instruments, driving Pro Tools via the IAC bus with audio connected via madi. I also have a Magma ExpressBox 3T connected to the other Thunderbolt port with an RME HDSPe MADI FX card. The HDX cards are connected to an SSL DeltaLink which is also working perfectly. I've done extensive tests with a massive Pro Tools file, loads of native plug-ins, Logic driving, and so far no signs of any problems whatsoever. Not one crash, even whilst doing my emails. It seems too good to be true, at least so far. My only worry is that if the MacBook Pro goes down I'm totally out of action, so I'm considering getting another MacBook Pro and cloning the current one as a backup. Or maybe a Mac Mini.......
Old 02-17-2014, 09:33 AM
Michael James Michael James is offline
Originally Posted by info@npp.co.uk View Post
... It seems too good to be true, at least so far. My only worry is that if the MacBook Pro goes down I'm totally out of action, so I'm considering getting another MacBook Pro and cloning the current one as a backup. Or maybe a Mac Mini.......
A cost effective solution might be to simply clone your boot drive and have it ready to go in the event that you need to buy a second MBP in a hurry.
I've heard that laptops are not as robust and durable as desktop computers, so it's probably a good idea.
Michael James
michaeljamesproducer.com
www.IndieProMix.com
System info: PT Ultimate 2019.6 HDX, Mac Pro 5,1 Westmere, OS 10.13.3, UAD2 Octo PCIe, 2x Lynx Aurora16 w LTHD cards, 1x Lynx Aurora(n) 32 ch analog I/O DigiLink, 4x Dangerous Convert-8 (AES via Lynx), Dangerous Convert-2 (AES via Lynx), Dangerous Vonvert AD+, Apogee Big Ben, SSD boot drive, external FW800 audio drives
Old 02-17-2014, 09:44 AM
gives's Avatar
gives gives is offline
Hi All,
Thanks in advance!
Just installed it on my Early 2011 MacBookPro and it runs fine here. Have not run too many sessions as I just got it going, but seems all good with Protools HD Native. I had to upgrade the OS to Mavericks, os I made the plunge. All seems good here. I did run Alsoft Disk Warriorv.4.4, after the OSMavericks Install and found a few directory issues that were easily fixed. Ran that from the DVD G
Gregory Ives, Composer/Sound Designer/Musician
http://www.gregives.com
https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int
Protools 2019.6 Ultimate HD Native Thunderbolt Avid HD IO
Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram
OSX Mojave 10.14.5, Digital Performer 9.5, Logic Pro X 10.4.6
Old 03-09-2014, 10:01 AM
thanks guys for all the replies and help! Will let you know how I get on.
MacBook Pro 13" (late 2011) with PT 10 musikasik macOS 5 01-12-2013 10:29 AM
New 2011 MacBook Pro i7 has fan running loud and fast with PT9 Nave128 macOS 56 05-10-2012 11:55 AM
Can Pro tools use 16gb ram on a Macbook Pro late 2011 trajan24 Pro Tools 10 9 12-19-2011 09:12 PM
Early 2011 MacBook Pro DJTezo411 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-27-2011 12:55 PM
2011 MacBook Pro/PT9 Graphics Freeze dnadig macOS 5 03-25-2011 12:40 PM
