Re: ProTools 11 Screen Freeze?
He said he upgraded to 24gb. 6x4gb sticks. One thing you can do is take out all but 2 sticks and see how it behaves. When I am trouble shooting a machine that's part of my ritual. I assume your using disk cache, so that would have to be adjusted. Trashed prefs, I'm sure. ? What about hard drives? All sata3 with large caches? You get this with or without VEP Pro? You started with 10.6.8 but where did you end up? I would prefer 10.8.5 personally
thanks for responding..
i have not tried to remove any ram. since the behavior didn't change by moving from 6 gigs to 24 gigs and on another machine at 12 gigs, i figured that's not it... but i'll give this a try all drives 7200 rpm sata3 64mb cache.. that's what i use for recording.. also use a 250 gig ssd for recording occassionally... i tested mavericks also, even though it's not supported.. right now i'm working in 10.8.5 it's been the smoothest so far... expt this freezing thing... i don't know what VEP Pro is. the orchestral library? i'm testing all this without any plug ins installed expt what comes with protools installer... i can't think of running it any leaner. thanks |
Old thread yes I know. By chance were you using 2 monitors?
I am using two identical monitors in "mirror" mode.
ProTools 2021.12, Lynx Aurora (n) 32 TB, Sibelius 23.2.0; OSX 10.14.6; Mac Mini: 3.2 GHz Intel Core i7; 64 GB 2667 MHz DDR4; Internal 2 TB SSD, External Sabrent TB 2 TB SSD Also ProTools 2021.12, 002R,; Mac Pro: 2 x 3.46 GHz 6-Core Intel Xeon; 128 GB 1333 MHz DDR3 ECC; Serial ATA Drives (Journaled HFS+): 2 x OWC Mercury Electra 3G 2 TB SSD; 3 x Seagate Barracudas 1.0 TB; External Firewire Drives (Journaled HFS+): 4 x Seagate Barracudas 1.5 TB and 6 x Seagate Barracudas 1.0 TB |
Axiom Pro 'Channel' Screen Freeze | TCreed88 | MIDI | 2 | 02-02-2011 08:10 PM |
Mac Pro...black screen freeze question! | acmost | Pro Tools TDM Systems (Mac) | 2 | 10-17-2007 12:11 PM |
Echo boy screen freeze | Greene | Pro Tools TDM Systems (Mac) | 1 | 07-28-2006 09:50 AM |
PT7 Screen Freeze for 10 secs | Jake Jackson | Pro Tools TDM Systems (Mac) | 6 | 03-09-2006 09:41 AM |
Screen Freeze | Sulaco | Digidesign Hardware & Software | 1 | 07-24-2002 05:54 PM |
