Loop play is not working
I don't know if anyone is having the same issue, but when I select an area and try to play it in a loop, it ignores it and simply continues forward.
Quick punch is not enabled No Tracks are in record mode Tried pre/post roll on off On a Windows system... I am at wits end.... Is anyone else having this issue? |
Re: Loop play is not working
Ok Never mind...I see my "Link Timeline and Edit Selection" needed to be selected....trying to delete this post but I can't see how
Might as well keep it up - someone else could have the same issue.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Error: "Pro Tools cannot be put online while in loop play or loop record mode." | msg6794 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-12-2016 06:09 AM |
Notation view edit while in play cause play to stop working. | soybalm | Pro Tools 10 | 1 | 04-18-2013 11:11 AM |
navigating during Loop play without removing the loop | remusjacobs | Pro Tools 10 | 1 | 08-10-2012 06:11 PM |
