"Pro Tools ran out of CPU power" message, then unusably glitchy playback afterwards
Every so often PT will throw up this error message:
Usually not a lot is happening in the session when this pops up, and I generally don't run a lot of plugins in a session anyway. Once I've dismissed the error message, PT playback is SUPER glitchy, like constant non-stop audio dropouts, such that it almost sounds like a comb filter or something. The only fix is to either quit and restart PT or to re-select my audio interface in Setup -> Playback Engine. The error message itself is fine, it's the fact that playback is unusably glitchy straight afterwards that's the big problem. Any idea why this is the case? |
Re: "Pro Tools ran out of CPU power" message, then unusably glitchy playback afterwar
Following +1
Protools 2019.12, HighSierra 10.13.6, 2x2.66 Ghz 6 Core intel Xeon, 24 Gb 1333 MHz DDR3 |
I have the same problem since 12.1! It is very annoying. Im using Fireface 800 with Yosemite.
Was having this problem earlier this week after committing my system drive to 10.10.5 and PT 12.4 after successful tests on my Test drive. So far the solution for me was to trash preferences, do a disk repair and do a full reboot.
Since then I've been able to run no problem, 3 hours at a time with pluggin heavy sessions with 25 tracks (no VI's)
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
What happens after 3 hours?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Also should mention - this was happening to me on 12.3.1 as well |
I would go snuggle up with my pregnant wife :P and watch TV
You can find the Pref Trasher tool here: New PT Prefs helper http://duc.avid.com/showthread.php?t=340741 Then after that empty your trash, run a disk repair and do a FULL reboot.
Gee, mustgroove, you didn't tell us ANYTHING about your host computer, not even what version of what OS. So my best guess on available info is the thing doesn't line up with the gizmo...... OR you're not using a qualified secondary drive.
Lol... but you're right, my system is a Macbook Pro 15" Late 2013, OS X 10.10.5 |
Error message: "Playback has reached end of session" | Wolfgang Eller | Pro Tools 12 | 3 | 10-04-2015 02:13 AM |
Pro Tools 11 - constantly get "your settings have changed" message opening sessions | kirkbross | Pro Tools 11 | 10 | 10-22-2013 07:36 PM |
Omnisphere and Stylus RMX: sounds are playing back "glitchy" | sylviesongs | Virtual Instruments | 0 | 10-25-2011 12:35 PM |
Pro Tools error message "Session must be an audio record volume" | DeejayMaurice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-10-2011 06:42 AM |
do i have to buy "european" version of digi002, or use "american" with power adaptor? | stoka | General Discussion | 3 | 10-04-2002 05:28 AM |
