FAST TRACK PRO problem with digital distortion
Hello! I recently set up PT9 on a new Macbook Pro this week. (2011, i7, 8gb ram, 2.2 ghz, 10.6.8) I'm in the process of learning how everything works still and have come across a problem.
When I try to record using my M-Audio Fast Track Pro, the audio in the mix channel and the recorded playback is distorted. Like a digital distortion, almost like a bit-crush effect. When I turn the mix volume on the interface down I can hear myself fine in the armed audio channel. Everything else is distorted including all of my recordings. I've tried installing the latest drivers several times, and I have no idea what can be causing this. Everything looks to be okay with the I/O configuration, and my FTP works like a charm with Ableton Live 8 on my PC. Help! |
Re: FAST TRACK PRO problem with digital distortion
Hi, I am having the same problem with the digital distortion on playback but I have a completely different set up. I am running a Mytek Stereo 96 ADC and DAC into the Optical ports on my MacBook pro.
I can only record the distortion by printing the actual playback. It does not print on the way in. The problem with the digital distortion on playback only started when I updated my OS to the latest 10.6.8. My next solution is to do a time machine backup and do a clean install off a OS cd and not update to the latest OS. In any case, please help!!!!!!! |
Digital Distortion on Playback Pro Tools 9
i solved my digital distortion problem with PT9. The problem was OS 10.6.8. i went back to 10.6.5 and everything went back to normal
I experienced distortion after upgrading to 9.0.3. Deleting the prefs and databases resolved the issue.
What version of PT9 are you using?
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
You can fix it in two ways, first go to system preferences, Fast track pro, and change form 24bit to 16bit. or the second fix, uncheck outputs 3 & 4.
Take care E |
King
Almost a year behind !!! Hahah Peach
FWIW, the Fast Track Pro has been a total failure with 9, regardless of what driver I try to use. XP with M-Powered 8 was fine, but Windows 7 and 9 have been useless(003 works dandy).
Fast Track Duo Seemingly Random Loud Bursts of Digital Distortion Independant of Prog | nathanc92109 | Pro Tools Express on Windows | 9 | 05-23-2016 06:23 PM |
M Audio Fast Track - Distortion, popping noises, etc... Solved-ALMOST | Bonez007 | Pro Tools SE and Essential (Win) | 4 | 04-12-2013 08:01 AM |
Fast track pro input distortion | Drapte | Pro Tools SE and Essential (Win) | 4 | 03-01-2013 05:48 PM |
PT 9 distortion on Fast track pro | tsidewalk | Windows | 2 | 11-27-2011 06:08 AM |
Distortion - Fast Track Pro interface | wordupdowndog | Pro Tools M-Powered (Win) | 2 | 12-19-2010 11:09 PM |
