Crash loop after install
After installing LE 8.0.1 I discovered that this installer that came with my 11 Rack is not compatible with Vista. I downloaded 8.0.3 I can only boot in safe mode but it will not let me uninstall and Digi stuff and I am stuck in the Blue Screen Crash loop. What do I do? Besides going back to OSX I need to test some windows plug-ins. I am using a 27" iMac i7 I have not used Windows in 10 years so I am behind the times a bit.
Re: Crash loop after install
Tried using Windows Add/remove programs that would not uninstall
The Protools Uninstaller worked. However the 8.0.3 installer just crashes Windows. What installer do I use with Windows Vista? |
Crashes during the Hardware Driver installs for the MBox Micro
M-Powered worked (After a few crashes) I wonder what's up with PE LE
install loop and install failures Solved.....so far | soybalm | Windows | 1 | 04-17-2012 08:40 PM |
loop crash still there in cs3 | tonwurm | Pro Tools TDM Systems (Mac) | 25 | 06-18-2009 09:12 AM |
How is the FWAudioCallback loop crash? | TCDet | Pro Tools TDM Systems (Mac) | 4 | 05-01-2009 10:10 AM |
Loop Crash | Siegfried Meier | Pro Tools TDM Systems (Mac) | 5 | 04-23-2009 07:33 AM |
Loop Crash... | TimNielsen | Pro Tools TDM Systems (Mac) | 5 | 03-24-2009 09:00 PM |
