Which format for external hard drive PC to Mac transfer?
Hey DUC!
I am about to get an external firewire drive for my 003R setup and am wondering about transferring files between my PC Desktop and Macbook (intel). I figure the easiest way is to format my firewire drive for recording with the macbook (Mac OS Extended also known as HFS+ format). Would I then need to have Macdrive on my PC to be able to transfer the files? I'm having some difficulty figuring out the most efficient method. First time Mac user as well as my first external drive. Any tips would be great! Cheers Andrew
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2023.9 / RME UFX+ Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 2023.9 |
Re: Which format for external hard drive PC to Mac transfer?
You'd need MacDrive if you did that.
I've been told (although I haven't done it myself) that if you use DOS to format the drive in the FAT-32 format, you can read it on PC or Mac without any problem. I haven't done that myself - I already had MacDrive when I was told that, so I haven't gone back to find out. You also need to make sure you enforce Mac/PC compatibility in the ProTools sessions.
Joshua L. Decatur, AL |
If you have Pro Tools 7.3 on both Mac and PC then you don't need to do anything. Pro Tools 7.3 includes HFS+ support for full compatibility.
Just use HFS+ formatted drives and you can use them to record and playback on both platforms. Rail
Thanks to you both.
I will be getting the 003R this weekend (001 exchange) so I assume it will come with 7.3. With the HFS+ support for both platforms inherit in 7.3 it should be simple to transfer PT sessions. Perfect. If I wanted to transfer files other than PT sessions, such as audio and video, I would then need something like Macdrive correct? Is Macdrive the only option? Does it work as seamlessly as it boasts? Again, thanks for the advice. Andrew
MacDrive works great! If you have MacDrive, don't install the 7.3 HFS+ support option.
Rail
Rail,
Another question: Because I thought the HFS option in 7.3 had more functionality than MacDrive, I installed it. Now that I installed the HFS option, should I remove MacDrive? If I do so, will I still be able to read HFS drives in Windows explorer? Thanks, cakes |
MacDrive 6.0.9 and later allowed Pro Tools to record.. but only very old versions of Pro Tools allowed it. Pro Tools 7.2 HD allowed this, and in 7.3 this was allowed in LE.
So if you have MacDrive, don't install the HFS+ option. Rail
Okay, I am remembering this now - Mediafour had written in the functionality to MacDrive, but Digi hadn't unlocked it yet in PT. I guess I missed the part in 7.3 where Digi said they unlocked it - I thought you still had to install the Digi HFS support (which I understand is just MacDrive repackaged) to get PT to read Mac drives.
Thanks for the clarification! cakes |
Error -36 Cannot transfer WAV files to external hard drive | airto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-06-2007 01:57 AM |
Which format for external hard drive PC to Mac transfer? | blizzard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 05-03-2007 12:51 PM |
How Do I Format an External Hard Drive? | wolfman_rob | Pro Tools TDM Systems (Mac) | 5 | 01-18-2007 07:29 PM |
Proper format for External Hard Drive | mfavila | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-21-2005 11:25 AM |
Can I Transfer 24/96 from an External Hard Drive? | ShakaBrah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-30-2005 06:20 AM |
