Old 03-15-2009, 08:11 AM
Alkimera Alkimera is offline
Default 2.0 or 2.4 Ghz ?
Hi Guys !
I was wondering if you can help me...
If want to use PT to mix mobile... wich processor is better 2.0 or 2.4 ? Is there a noticeable difference ?
I'm gonna be using plugins most of the time (not virtual instruments)
Thanks !
Old 03-15-2009, 09:52 AM
TOM@METRO's Avatar
Default Re: 2.0 or 2.4 Ghz ?
Faster is better.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-16-2009, 09:16 AM
But is the difference in performance worth the difference in price value ?
ie. is the macbook 2.4ghz worth the extra money over the macbook 2.0ghz ??
THANKS !
Old 03-16-2009, 09:19 AM
NHH NHH is offline
If you can notice a difference between 2.0Ghz and 2.4Ghz ... you probably have special powers that should be harnessed for the good of mankind.
Old 03-16-2009, 10:20 AM
SDDP SDDP is offline
WOW, that was awesome
-Mac Pro 7,1 16core 3.2GHz 96GB
-OSX 12.7.2
-PTHDN 2023.12 Ultimate
-HD Omni
-BM Intensity Pro
-Waves Mercury+SSL4000 Collection+Abbey Roads
-iZotope RX10 Advanced
-iZotope Post Production Suite 6
-iZotope Music Production Suite 5
-HALO UP/DOWN MIX
-ANYMIX
-Delonghi Perfecta ESAM 5600.S
Old 03-16-2009, 10:26 AM
flommer flommer is offline
Exclamation Re: 2.0 or 2.4 Ghz ?
THANKS !
Do Not buy a new model MacBook... No Firewire ports for your recording HD
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 03-16-2009, 10:29 AM
TOM@METRO's Avatar
If you are pushing you system to the limits, you’ll be better off with a faster computer, if your not, you will not likely never see a difference. And good point above, no Firewire is a problem.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 03-16-2009, 10:30 AM
bobwitte bobwitte is offline
A 20% cpu speed difference, assuming other factors are approx. the same (memory mainly) will be noticeable with respect to the number of plugins/effects that you can apply. I wish I had another 20%. I agree that for many non cpu intensive tasks, the speed is not noticeable - word prosessing, email, internet browsing for example. But throw a compressor, EQ on each channel, add a reverbe or two on an Aux, etc. and that 20% comes in handy.
Now, what is that worth depends on what you are using PT's for and if you will be pushing the CPU with the work you do.
Old 03-16-2009, 01:08 PM
Good points ... but the thing is, I'm gonna be using the macbook ONLY for mixing mobile, just to get some work done outside the studio.
I'll not need an external HD, so no firewire is needed (only a usb for the mbox micro)
For example, if I use 1 altiverb, 2 dverbs, 4 Waves SSL, 3 Smack and 10 EQIII with a limiter and a comp in the master bus, will it work with a 2.0ghz or should I get the 2.4ghz ?
Thanks again !
Old 03-16-2009, 01:14 PM
Mr. Anderson Mr. Anderson is offline
If you say so. I will strongly disagree.
