#21
Re: midi sustain pedal messages bug
I also have some few note cutoffs.
I thought this was my old Roland A80's fault or bad contact in my sustain pedal. When i look at the sustain controller(#64) view i notice there are some inbetween values now and then. I thought there should be either 0 or 127 value on the sustain controller. It is when the values are in between 0 and 127 I have these note cutoffs. Can anyone with these problems look in the controller lane and check the values. Maybe it isnt the A80 afterall?? Svein |
#22
For us to investigate this further, please tell us:
1. What synths this is happening with and the version number of the synth you're using. 2. What MIDI interface you're using 3. Do you have any ReWire instruments in the session 4. What controller keyboard you're using and how is it connected (MIDI or USB) 5. Pro Tools version and computer specs |
#23
1 Ivory, for one 2 MOTU Fastlane 3 No 4 Edirol PCR M80 5 Mac Pro 2g PT 7.2.1 |
#24
1. Kontakt 2(latest)
2. Motu MTP AV USB 3. I use reason(latest) regulary 4. Roland A80 midi to MTP 5. PT 7.2cs1 HD4 accel G4 dual 1.25(fw800 model)2gb ram Svein |
#25
1. Reason 3.05-Combinator Or NN-XT. Also happening with Kontakt 2.1.
2. Emagic Unitor 8 3. Yes, Reason through rewire. 4. Yamaha S-80 through the unitor 8. 5. Computer dual 2.7 gig with 2.5 megs ram OS 10.4.7 running ProTools HD 7.1.1. This problem has been happening as long as recent memory will permit. I believe all the way back to 6.9.2. But really began to notice it in 7 and up. |
#26
bumpity bump! ....post if you too are having problems! As you can tell, some of us really want to get this PITA fixed. )
#27
yeah this is really turning into a nightmare..audio works fine in 7.2 but midi especially with virtual synths is just terrible. midi messages are all jumbled not only sustain control but if you check your velocity even when controller is set to fixed you see jumps..don't know if it is a midi io problem or something in the software..although it was working just fine in 6+. also soft synths slow the system down to a crawl..
pt 7.2 hd3 accel g5 dual 2gig(8gigs ram), midi io ,192s and 96ios ,big ben clock. gary vandy audio production
www.garyvandy.com |
#28
bump! (Someone's gotta care about this, right?)
#29
In short, this sustain pedal issue is appalling and highly unprofessional...We spent just spent $70,000 between two rooms assured that everything was 'working' properly.
QUAD G5 2.5GHZ 8GB RAM ATTO SCSI Expansion Chassis HD3 7.1cs9 192 96 SYNC I/O MIDI I/O |
#30
this is a very serious issue..it is defenitly getting old..i am so tired of redrawing sustain comands especially after each punch in on midi..happens with every soft synth..and virtual instrument when a sustain pedal is in use..in fact there are problems with pressure sensitive keyboard when set on variable.
studio 1 hd3 pt 7.2.1 accel g5 dual 2gig,192s ,96s,midi io,big ben clock. studio 2 002 pt 7.2le rack.g5 dual 2gig midi io gary vandy audio production
www.garyvandy.com |
Midi Controller Sustain Pedal | BuzzsawWhitey | MIDI | 5 | 02-04-2012 09:15 AM |
Midi sustain pedal question | Burst2flame | Pro Tools 9 | 1 | 11-17-2010 12:21 AM |
Sustain Pedal Midi Keyboard | Matt Darcy | General Discussion | 1 | 01-22-2009 07:48 AM |
MIDI Sustain Pedal? | rockwithrespect | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-28-2005 04:47 PM |
Setting Up Midi Sustain Pedal | cuethevocals | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-07-2005 10:35 AM |
