AAE error-1180....over and over
Pro Tools ultimate HDX on Catalina.
Anybody know what is causing this? Sleep and hibernate are deactivated. |
Re: AAE error-1180....over and over
Not with zero system specs, no.
Brand new Mac mini with HDX chassis, 32 gigs of Ram, i7 processor, apogee Symphony MKII, Pro Tools Ultimate
Specifically, what version of Pro Tools? “Ultimate” 2019, 2020, .x??
Is your version compatible with the operating system? |
Just uninstalled and reinstalled everything. Hopefully that works. But this had only been installed on this computer for about 6 weeks |
The latest is 2020.9.1. Is that what you’re running?
Do you fall under this heading? You didn’t give us an actual version “number.” The “latest,” unfortunately, isn’t enough info, and it might NOT be the latest.
“We have become aware of an issue that may affect certain machines running Pro Tools 2019.12 or later on macOS 10.15.4. When recording or playing back audio, the OS may lock up and require a hard reboot. We have found that Thunderbolt 2 spinning disk drives are more susceptible to this issue. We have worked closely with Apple to resolve this issue with high priority. We recommend that you continue to run Pro Tools on macOS 10.15.3 or 10.15.5, and refrain from installing macOS 10.15.4. Thank you for your patience.“ |
Where did you find that? I should probably know, but I don’t. I went years without issues until “upgrading” this year |
Compatibility documents. I had to dig around for them.
Here you go: https://avid.secure.force.com/pkb/ar...tibility-Chart |
Transfer of Ownership Fail - Error: Error occurred while loading a Visualforce page | Chevron | Licensing & Accounts | 10 | 12-19-2019 12:35 PM |
AAE error -1180 | MrKidd74 | Pro Tools 12 | 6 | 03-26-2018 12:27 PM |
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error | EricMulhern | macOS | 1 | 11-20-2011 05:39 PM |
Error type 10,address error ,illegal error, buss error ,illegal instruction | KasticK | Pro Tools TDM Systems (Mac) | 3 | 05-14-2003 11:21 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
