reading Audio file metadata ?
I'm doing something when editing, slip of the right click, with a specific tool (From the multi tool) while holding command down - I just can't figure out WHAT is causing THIS DIALOG AND ANALYSIS to Pop up, and highlight the region with a bright yellow box.
Am I TCE'ing? I can't "Force the dialog", but it's popping up about 7 or 8 times per comp. Any ideas what this is ?
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Re: reading Audio file metadata ?
PT is reading the metadata of the audio files to determine whether it should 'match' them based on criteria in the files.
If you select 'track id' as the match criteria, then command-click on the highlighted region with the selector tool, any other audio file that has the same 'name' in it's metadata and overlaps in time will pop up in a contextual menu. Selecting another file from the menu swaps out selected audio for the other file. It's useful if you have an eight-track field recorder, and have eight tracks of production audio from a film shoot. With one track in the session, you can highlight a word or phrase, and swap it out for another channel (i.e. boom to radio or one actor's radio to another actor's radio). It gets interesting when you use sibliminator from maggot software. Sibliminator takes a group of files and forces then to be siblings, then if they overlap in time, you can swap them out using the technique above. We use if for ADR - all the takes get sibliminated, then individual words can be swapped (for example). It has applications in music too - sibliminate your vocal tracks, and comping is a breeze. |
There's "match from timecode only" in the match menu (7.4 and up). Doesn't that do the same?
http://felixrost.de |
I just got it to do this by right-clicking on a region with the Apple key held down. When I tried it again, it wouldn't do it anymore.
It can be a bummer when you are working quickly and this happens to a long region - it can take a while.
www.clifnorrell.com |
Yeah that's my complaint... I want to shut it off - I don't use this work flow, and it's popping up, and analyzing whole files, in the middle of my comp edits. I'm cutting all the vox on a project, and comping every day right now - and this is a bit of a P.I.T.A - obviously a "New Analysis" Shortcut for PT8 as I haven't changed my workflow in a few years, and this is a new dialog for me. Anyone know if there's an Option / Preference - to disable this?
request: make "reading audio file metadata" background task | Felix Rost | Pro Tools TDM Systems (Mac) | 7 | 03-11-2011 07:35 AM |
"reading audio file metadata"--key command? | Floydio | Pro Tools TDM Systems (Mac) | 3 | 10-27-2010 02:23 PM |
file reading metadata by mistake | garnoil | Post - Surround - Video | 2 | 10-07-2010 09:36 AM |
Audio File Metadata - toggle off??? | digidub | Post - Surround - Video | 6 | 02-24-2010 05:04 AM |
Reading audio file metadata???!!! | GeneOuse | Pro Tools TDM Systems (Win) | 1 | 01-21-2008 10:07 PM |
