Old 09-03-2007, 10:07 AM
Palo Alto Palo Alto is offline
Default Xmon output meter ????
hi there
i'm unable to understand the metering of the main section of my Dcontrol in the output meter position : when i send a signal to the main input of the xmon (from my 192io), the meter is metering nothing. When i send a signal on the surround inputs, the meters indicates something, but the calibration screws of the xmon have no influence on the level. so there is certainly something that i didn't understand... any help ?
Palo Alto
Old 09-20-2007, 10:46 AM
Robin_Parnaby Robin_Parnaby is offline
Default Re: Xmon output meter ????
The control surface meters are sourced digitally from Pro Tools (via ethernet) whenever Main is selected in the monitor input source selector. When Main is not selected the surface meters are driven from XMon.
The calibration trimpots should effect the meter level when you meter your surround input, unless you are in Sum mode then it could be meterering Main over ethernet.
For the Main meter problem check the I/O setup is correct.
Robin
No OutPut No meter? What? Nathan W. Pro Tools 11 0 11-14-2013 02:03 PM
XMON alt output for TV abayman65 ICON & C|24 0 01-08-2009 06:08 AM
Questions about XMON inputs and output audio quality. Quan ICON & C|24 4 10-11-2008 08:00 AM
D-Control Center Meter and XMON legasafe ICON & C|24 1 05-12-2008 01:20 PM
XMON central meter section not showing meters tonmeistermat ICON & C|24 2 11-15-2006 04:38 AM
