Old 03-14-2007, 07:32 AM
Seeee Seeee is offline
Default Does \"Save Session Copy In\" set disk allocation?
Does "Save Session Copy In" set disk allocation to the drive you copied it to.
I don't think it does and am just shuiddering thinking I have to open 10 sessions and set the disk allocation NOW or I'll be finding files scattered on other drives.
Old 03-14-2007, 07:53 AM
RobMacki RobMacki is offline
Default Re: Does \"Save Session Copy In\" set disk allocation? *DELETED*
Post deleted by RobMacki
Old 03-14-2007, 07:55 AM
Best to verify now.
I was curious too so I check with a test file that actually had no audio files folder in the session root folder yet.
What happened was a little scary.
I saved session to another drive named "Deliveries".
The new session appeared in the Deliveries drive as expected.
But when I created a tone file with AS, the file appeared in an new folder named "Deliveries" on the original drive.
Then I did a "Save Copy In..." another drive and this time I copied the file.
This time, when the new session opened, the dialog box "original disc allocation cannot be used....." opened up and disc allocation was set to the root folder of the new session on the same drive.
So if you copy the files, yes, but if you don't then no.
P. 54 Ref Guide too.
Old 03-14-2007, 08:28 AM
Yeah, I was meaning with Save Session Copy In " with the "copy audio files" options. so thats a little comforting that as long as I select it, i'll be prompted when i open it. i think to play it safe i am going to erase the original drive and rename it.
Old 03-14-2007, 08:59 AM
jimlongo's Avatar
jimlongo jimlongo is offline
Disk Allocation is not reliable with Save Session Copy, nor with Importing Session Data.
You should really always check before you do anything of consequence.
FEATURE REQUEST: When I open a session that has Fade Files missing could I please check the Disk Allocation before selecting the (paraphrased) "Rebuild Fades without searching" option
noise | jimlongo
Old 03-14-2007, 09:07 AM
Scott Goldberg Scott Goldberg is offline
Jim is right but Save Session Copy DOES change your disk allocation to the new drive but I also always check.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
URGENT disk error / save session copy in.. problem viaspiaggia Pro Tools TDM Systems (Mac) 7 09-17-2003 07:21 AM
PT6/OSX: Auto-save and Disk Allocation andrej770 Pro Tools TDM Systems (Mac) 1 04-07-2003 09:20 PM
disk error 37 on "Save session copy in" simonchase Pro Tools TDM Systems (Mac) 3 07-03-2002 02:17 PM
disk error 37 on "Save session copy in" simonchase Pro Tools TDM Systems (Mac) 0 07-03-2002 03:37 AM
"Save Session Copy In" Disk Error? Eric Bazilian Pro Tools TDM Systems (Mac) 7 01-09-2001 12:45 AM
