PT LE and Tokyo 2.5
I must be missing a step, but I am unable to select Tokyo as a send for a MIDI track. I have reconfiged OMS for the Tokyo and have DirectConnect installed. I also use Bitheadz software over DC. They are listed in the send list, but no Tokyo. Any ideas?
Re: PT LE and Tokyo 2.5
double click the iac driver in oms, type in "into tokyo" or something, then you can select that as the output from a pt midi track.
You then have to set tokyo to look at that iac buss... |
Did you install the Tokyo plug-in in your DAE plug-in folder? The installer does not install that plug-in.
MS |
Thanks, guys. Naming the IAC driver was the ticket.
OT- Anyone here in Tokyo? | valvebrother | General Discussion | 0 | 03-15-2002 02:30 PM |
OT- Anyone here in Tokyo? | valvebrother | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-14-2002 09:48 AM |
motormix with tokyo/reason | beardeddubster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-18-2002 05:11 PM |
Tokyo plugin Dae Error | Tom_Weber | Pro Tools TDM Systems (Mac) | 0 | 04-07-2001 07:31 AM |
Tokyo plug | chengod | Digidesign Hardware & Software | 0 | 11-28-2000 04:57 AM |
