Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 12-05-2018, 01:28 AM
Richard Starkey's Avatar
Richard Starkey Richard Starkey is offline
Default Coalesce VCA problem
When I try to coalesce VCA from S6’s softkeys, it sometimes work but most of the time it doesn’t.
If I do it with the mouse on protools menu it works just fine.
Does anyone has this problem too ? Am I misunderstanding something about this function ?
Thanks !
Envoyé de mon iPhone en utilisant Tapatalk
Old 12-05-2018, 04:35 PM
creativecontrol's Avatar
Default Re: Coalesce VCA problem
Greetings,
Any idea if you remember seeing an LED illuminated on the Soft Key when you’ve selected a VCA Master - and also, does it get extinguished when you invoke the command?
Jeff
Jeff Komar
Old 12-06-2018, 12:25 AM
Yes it does all of this, but I think I finally found that it doesn’t work only when the VCA fader is hidden in the Pro Tools session. If it’s shown then it works fine. Weird behavior as it works fine when i do this on selecting the VCA and right click on the track list (in PT) no matter if the VCA is hidden or not.
Old 12-06-2018, 09:47 AM
Thanks. I'm seeing that behavior here as well. It looks to be a bug. We will get it logged.
best,
Jeff
Jeff Komar
Old 05-24-2019, 03:10 AM
Hello,
seems like it has'nt change yet with 2019 vesion ?
VCA coalesce not working... pqlior@mac.com Pro Tools 2018 0 09-20-2018 02:42 PM
Bug: VCA Won't Coalesce if Groups are Suspended Dizzi45Z Pro Tools 12 1 02-04-2016 04:12 PM
Coalesce 'Follow Main Pan' ? FlorianE Pro Tools TDM Systems (Mac) 0 05-11-2012 01:09 PM
How do I coalesce volume automation? sugarplum Pro Tools TDM Systems (Mac) 11 07-20-2002 08:16 AM
