Omni I/O - How to set up AES outputs?
Has anyone figured out how to set discreet or stereo pair AES/EBU outputs on the Omni I/O? The only way I can even get the Omni to let me access the Digital outputs is to set up the AES outputs as a "7.1 Monitor" which then doesn't give me access to stereo pairs of outputs within the sub-paths of the 7.1 channels.
Surely there's a way to make the AES/EBU on the Omni behave like a 192 I/O where I can just select the physical output pairs within each channel of the session w/o having to deal with the whole "monitor" section right? |
Re: Omni I/O - How to set up AES outputs?
Nvm, figured it out. You have to essentially disable the 'monitor' section in order to access physical I/O directly.
I'm sorta disappointed, I didn't realize the Omni was only capable of a flimsy 8 I/O at a time. Lots of connection options, but you can only use 8 channels at a time, not very flexible. |
Just curious, what did you think it was capable of?
16 I/O is the minimum on the other HD interfaces, figured Omni would at least be able to do that.
so just picking up on this thread......you cant use the 8 analogue out and 8 ADAT out at the same time like you can on other interfaces or even the humble 003?
No, you can't.
The Omni is a total of 8 in, 8 out, in various combinations. Keep in mind there's also only 4 analog ins (4 a/d converters and 8 d/a converters in the unit). So for coming out, you could do various combinations like 8 analog out, or 4 analog out, 2 channels spidf and 2 channels adat, or 6 channels adat and 2 channels spidf, etc. For going in, the same thing, only as mentioned it's a total of 4 analog in, and the other 4 channels must be digital. Keep in mind also that the spidf and AES is either/or. You can't use spidf and aes at the same time. In the I/O setup they show up as "digital out" (vs. adat/optical out), and once that's selected, you would choose either one. Note that there is one other analog out option, which is a hard wired analog out to the headphone jack, for a cue mix (which shows up as another option in the i/o setup). There may be an option, using a y-adapter, to use that as another stereo analog out for using with a mixer or summing box, etc. |
yeah right well then this interface really isn't suited for me.....8x8x8 or 16x16 it is....then the question has to be asked....HD or native?
HD Omni unable to un mute CR outputs | soundeq | Pro Tools TDM Systems (Mac) | 8 | 11-02-2012 10:19 AM |
DigiSnake for HD Omni DB25 AES outputs | rokitpowr | Pro Tools HDX & HD Native Systems (Mac) | 1 | 10-31-2012 01:49 PM |
Omni mirrored outputs level drop | Picture Start | Pro Tools HDX & HD Native Systems (Mac) | 0 | 04-05-2012 09:21 PM |
Question about OMNI outputs | IO Composer | Pro Tools TDM Systems (Mac) | 0 | 12-15-2011 11:00 AM |
01V 18bit analog omni outputs? | east3rdst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-07-2001 08:26 PM |
