Plug ins not saving
Hi guys
I recently upgraded my system to a new mac running PT 2020.5. Having some strange issues. In particular. Some plug ins are not saving when I adjust a preset and try to save it. Seems to be mostly happening to instrument plugs as far as I can tell. Has anyone experienced the same and found a solution?
PT 2020.12.0 & Logic Pro X SPL Crimson Mac Catalina 10.15.5 Mac (Retina 4K, 21.5-inch, 2019) 3 GHz 6-Core Intel Core i5 16 GB 2667 MHz DDR4 |
Re: Plug ins not saving
Maybe a little bit more information about your config, and which plugins in particular you have problems... are the plugins updated to latest version, etc...
Hi
Sorry, I thought it might have been a common problem. Well Kontakt is one. I'd make a preset in Prism that seemed to save but when I came back to the project a different preset was in its place. Then I'd change it back, press play and the other preset would play instead of mine. LOOM (synth), I'd adjust a preset to taste. Press play and the original would be back. They are all the latest versions.
Some questions: How are you saving the preset - using Kontakt's save? I'd not rely on PT saving the preset but instead use the plugin's save mechanism to do so. From the sound of it I'm guessing you're using an instrument track to hold the vi and the MIDI. Make sure there are no unintended patch change events in the MIDI. Use the MIDI event list to check for that. |
Thanks Jack
Yes I am using the plug in's save. Then saving the session. Yes I'm using an instrument track to hold the vi and the MIDI. Ive opened the MIDI event list but dont see anything untoward there but I must admit Im not sure what Im looking for.
Google for a list of MIDI events - they're called CC's or continuous controllers and that will tell you what things mean. That and reading the PT reference guide aka The Manual.
Thanks
Some of my Wave Arts plugins do that on Win 10/PT 2020.3. Close the gui, reopen, it’s gone back to “default.” Odd.
Plug-In Maps not saving??? 8??? | SBR1710 | Virtual Instruments | 15 | 12-31-2008 11:41 AM |
Saving Plug-In Maps PT 8, Bug??? | SBR1710 | Virtual Instruments | 0 | 12-30-2008 08:30 AM |
Saving plug-in settings | Mark Seyler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-24-2006 03:22 PM |
saving plug ins | thenchel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-11-2005 10:58 AM |
saving plug-in settings | PC Lynn | Pro Tools TDM Systems (Win) | 1 | 08-20-2000 03:20 AM |
