Old 06-08-2011, 02:26 AM
andymac andymac is offline
Default "Save" not saving
Hi all, newish PT user and my first post here!
I'm running PT HD2 Accel with a DCommand 8, and occasionally I get a situation where "save" doesn't work - both on the DCommand and from the file menu.
The button led on the DCommand doesn't go out, and when I use the file menu save instead, "saving" flashes in the bottom left corner, but again, the led doesn't go out.
Further evidence that it isn't actually saving is that if I do a save then immediately quit, I get an on screen prompt asking if I want to save changes.
As I said, this is intermittent, and I can't find any pattern to it.
Anyone else experienced this?
Thanks in advance,
Andy
Old 06-09-2011, 01:54 PM
ZEUSS ZEUSS is offline
Default Re: "Save" not saving
Are you using the Massey delay plug in the session?
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 06-10-2011, 03:08 AM
Nope, I don't have that one.
Old 07-07-2011, 03:41 PM
kippertie kippertie is offline
You are pressing the save button twice aren't you?
first press - blinks red - not saved, second press - not lit - saved.
Can't help you with no save from menu though...
Old 07-07-2011, 05:02 PM
Stig Eliassen's Avatar
What are your system specs? Have you tried trashing the PT preferences?
Old 07-07-2011, 06:59 PM
moofie moofie is offline
If you have the Digidesign "PhaseScope" plugin open/displayed in your PT session AND set to LEQA mode... it can appear that PT hasn't "Saved" after either pressing save on the D-Control/Command or via the Menu.
PT has actually saved your session but the plugin is in a constant state of "measurement" so in theory, the instant after you hit save, the session state has changed because of the way that Plugin operates.
Close the plugin window or switch it to Phase mode... hit Save... no more red lights.
This may or may not help you chasing your "bug" but my 2c.
Cheers
Tom
Old 07-11-2011, 01:55 AM
Cheers
Tom
That fixed it
Thank you Tom!
"cannot save "XXXXXX" because while translating I/O settings" tdawgg Pro Tools 10 14 10-26-2013 02:27 PM
Force PT10 to make a "Fade Files" folder when saving .ptf? gguardia Pro Tools 10 2 06-15-2012 12:50 PM
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." Elias Stiza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-10-2012 07:06 PM
DAE error 9060, then "can't save error -50", then "can't eject drive" glankrudolph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-17-2009 03:24 PM
"Newbie" needs help on "save" and "drives" Thomas C. Gass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-30-2001 11:43 PM
