Old 07-06-2008, 10:11 PM
Mojosound Mojosound is offline
Default c24/no sound from Alt monitors
I am new to this website. Having problems with c24/ no sound from alt monitors. Worked perfectly fine night before, next day no sound. Using 1/4 monitor alt out to jbl 4328. Tried jbl's with other sound source and work fine. I noticed alt mon button won't stay on. If I hold down for two seconds-alt mon trim comes on. Also when I turn control room alt mon volume knob--I get "control room no cal"?Please help
Old 07-09-2008, 02:48 AM
Patta Patta is offline
Default Re: c24/no sound from Alt monitors
Hi there.
Did you mange to fix this problem?
Ours is exhibiting similar symptoms....
Not sure what to do. Re-reading the guide now...
Cheers
Old 07-09-2008, 02:27 PM
Everything is working fine now, here is the help I got from digi support: #4 fixed the problem.
Hi John,
> I left a message for you on the studio phone number... I spoke with
an engineer here, who wants a little more information in these areas:
> 1) Does the distorted audio turn on and off when you toggle alt
monitor switch, or does it stay constant? Is the distorted audio loud
or quiet? Does it's volume change when you turn the Control Room rotary
encoder? Is the distorted audio the same in the L and R speakers?
> 2) Is the headphone audio output on the C|24 also distorted?
> 3) When you turn the control room rotary knob, you see the "No
Cal". If you then press the alt monitor switch and then turn the
control room knob, do you get the same No Cal display? Try pressing the
Alt Monitor switch a few times and turning the Control Room encoder and
see if it always displays No Cal.
> 4) Reset all 3 items that are stored in Flash memory - Utities>
System> Reset User Prefs, Reset Analog Routes, Reset Monitor Gains.
Then hit OK and see if it resolved the problem.
> 5) Ventilation and power. Is the board well ventilated. If it
is in a desk that has no breathing room behind the control or below the
console, heat could be an issue. Also, please describe how the board is
powered... Is it going into a UPC?
> Also, I heard back from the repair department about the C|24 that you
sent back to us. There was a simple short on the submixer pcb, which
was causing a problem with the whole system booting...
no sound thru monitors plz help shamanrock Windows 0 01-04-2012 03:45 PM
no sound through studio monitors!!! Southernbudz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-22-2011 06:36 PM
no sound through monitors chriscapie macOS 1 02-04-2011 04:14 PM
No sound out of my monitors or headphones Baumtracks macOS 12 01-11-2011 07:03 PM
Monitors aren't playing sound chrystal6880 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-04-2007 03:15 PM
