Old 09-21-2007, 11:50 AM
subwoof subwoof is offline
Default \"Join\" automation button not working
Is anyone able to use the "join" button in the automation section of their D-Command? Mine only works from the software page, not the physical button.
Using OS 7.2cs4 on a G5 Quad processor with expansion chassis.
Michael McDonough, M.P.S.E.
Michael McDonough Sound Design
Old 09-25-2007, 08:47 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: \"Join\" automation button not working
just to make sure it's not the led that's broken :
try following little scenario :
1. put a track in LATCH mode. / view in the edit window to volume ...
2. start playback and do some fader moves for like 15 seconds or so ....
3. then press rewind and let the track play
checkpoint : do you see the join button illuminated at this point ?
if not ... PRESS it anyhow and check wether :
- from the point on you pressed the join button the volume line turned red (indicating you're actively writing automation)
- if the automation led on the channelstrip on the controller is blinking (again indicating you're writing automation)
What say you ?
if all that fails : go to the utility pages :
- press the utility button and then : Test / LED / Switch
Now when you press the JOIN button ... what do the softkey section leds indicate ?
They should indicate the position of the join button (row / number etc ... )
What say you ?
These steps should tell you wether there's something wrong with the hardware ... 99% sure that is.
Chris
Chris Lambrechts
Applications Specialist- Live Sound
C24 Input button not working tzic ICON & C|24 0 07-01-2013 10:46 AM
show/hide automation lane button musical paradigm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-06-2013 11:23 PM
BUG 10.2: cancel button not working Frank Kruse Post - Surround - Video 1 07-07-2012 09:29 PM
Help! Automation button missing from plug-ins! sdgard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-08-2008 04:56 PM
Pre-fader button not working? toekneebullard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-06-2006 01:32 PM
