Old 12-17-2005, 01:45 PM
mark.jnes mark.jnes is offline
Default really struggling
I am using a firewire 1814 with windows xp, centrino laptop and pro tools m powered, just upgraded to 7. Basically when I start my M box 1814 up it works fine, I can access the software controller no problem. Once I start pro tools the 1814 software controller panel freezes after a while and it says not responding. No audio then gets to protools, any help[ is greatly appreciated.
Old 12-17-2005, 04:25 PM
fizbin fizbin is offline
Default Re: really struggling
Do you have any other firewire devices running? Do you get a hard freeze where you have to reset your computer?
Check the event log for errors. Go to Start>Run and enter "eventvwr" then let us know if you see any "System" or "Application" errors marked around the time that the freeze occurred. Post the text from those errors in the log.
fizbin
Old 01-10-2006, 06:21 AM
rmh rmh is offline
Same problem here, exactly. Also with a Centrino laptop. Freezes even when booting a completely clean system without my external FW hard drive attached. I can get up to two or three minutes of operation sometimes before this happens.
Old 01-18-2006, 05:33 PM
rmh rmh is offline
Are you using an onboard FW port? Which laptop are you using? I fixed some problems, including one that sounds very much like yours, by using an external Cardbus firewire adapter and turning off the onboard FW port.
Struggling to record FlowEthic Pro Tools 9 3 03-09-2011 11:10 AM
really struggling mark.jnes Pro Tools M-Powered (Win) 0 12-17-2005 01:45 PM
"still struggling with wavelab" hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-30-2005 08:47 AM
Struggling - is this possible? protein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-14-2004 07:19 AM
struggling for I/Os wlldeans Pro Tools TDM Systems (Mac) 0 11-03-2003 03:31 PM
