Old 10-15-2012, 09:59 AM
THASAINT45 THASAINT45 is offline
Default How to hear played notes (transposed)
is it possible to perform a midi part transposed before recording?
Old 10-15-2012, 10:13 AM
Stig Eliassen's Avatar
Default
Record-enable the track, and set the transpose value in the MIDI real-time properties (edit window).
Old 10-15-2012, 11:19 AM
Default Re: How to hear played notes (transposed)
thanks for the advice. i tried that but it stills comes up sounding like the same
key.
Old 10-15-2012, 08:59 PM
lvly5t lvly5t is offline
I would also like to know this. good question
Old 10-16-2012, 05:32 AM
Default
key.
Is the transpose button highlighted (active)? Have you entered a transpose value? The track record-enabled? If this doesn't work, I don't know what the problem is. Works just fine here.
Manually played MIDI Notes arrive earlier than played. SmokinBaldMonkey macOS 7 10-16-2019 06:47 AM
Can you see MIDI notes that are being played in PT11? ianbee Windows 6 09-15-2013 08:55 PM
Can't hear MIDI notes played via Instrument mirovaz macOS 2 02-07-2013 10:53 AM
Notes played in Midi Editor Nullifer Pro Tools M-Powered (Win) 2 04-01-2011 02:04 PM
How to hear sounds played on PC via Digi 002? alexduncan1974 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-28-2009 09:52 PM
