EWQL + Kompakt for me...?
Hey all,
I've been looking at the EastWest Silver library as a way to have some entry-level film composition options. Entry-level in that I can't justify great spending on this, although I have a classical background and know how to orchestrate. I'm fine with the 16bit, and (at least for now), the lack of ambience control. Mostly doing faux hollywood style orchestrations for personal projects. I'm running HD3 PT 6.9 on OS 10.3.9 with 3gig of RAM in a Dual 2gig G5 (PPC) and a large FW800 drive. Will that work with Kompakt as RTAS (running w/ large buffer, no ADC)? I've read a lot of problems, but I don't know if it's because the Platinum Libraries are much more intense, etc. Anyone with this setup working properly? Thanks, - p
G4 dual 1ghz QS (1.5gig RAM) / OSX v10.3.9 / HD4 / AD8K / PT v6.9 |
Re: EWQL + Kompakt for me...?
the silver is only 16 bit so the load is minimal but you will need to put a ton of RAM in there. and load the libraries to a separate drive
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Hey,
Thanks for the input. Yes, I was hoping the smaller bit-size would help with performance. As far as your comment on RAM, I was under the impression that Panther and PT6 it can only take advantage of around 3gig of RAM. Unless you're talking about running Kontakt as a separate app, which I'd like to avoid if possible. Anyone able to confirm that...? - p
I dont know where you got that size limitation
but when you start loading VI's it starts sucking up RAM I know users with 8 gigs in the G5 and still seem low at times and I'm only referring to RTAS VI's Also you should take advantage of the NI DFD option to keep RAM consumption low, and the libraries on there own drive
the size limitation comes from the Computer. 32 bit Applications will only utilize so much RAM. if you have 8 GIG of RAM and only PT open, you will not usee all 8 GIGS. from Jon Connolly: Quote:
i have had good luck with EWQLSO. in fact i am using it righ now. happy with it. done some great stuff with it. but i am expanding beyond it.......(to Vienna and Sonic Implants...on another CPU) i do run into issues because i make BIG arrangements. the application bogs down, Saving becomes a pain because it takes so long -- the autosave makes everything stop. but note, this is just when i use huge amounts of Sample VI's. but it doesn't crash and i can run afair amount. or print, de-activate, and move on. as a starter for your music, i think it will be great. and then you'll want other things fro other flavors. each library has it strengths and weaknesses. The EWQLSO is good, but can be a tad bright, aggressive sounding and a tad big..... nothing is perfect, expect the real thing in the right circumstances. i say go for it.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
The EWQL Libraries Can Stream from Disk DFD
Don't know it they will work with Protools 6.9???? |
*** duplicate post ***
Hey thanks for the responses... Hey Tom, I'm the guy that emailed you.
That's a good question NuBus. DFD seems like a strong idea for making that all work properly. I own 7, but don't want to deal with upgrading *all* my plugs for this new tool if I don't have to. Anyone know if DFD is stable in 6.9?
Thanks for the link. Are you saying this is the one that works well with 6.9?
Thanks, - p
Kompakt Instruments in PT | VincePro | Pro Tools TDM Systems (Mac) | 16 | 07-30-2006 08:51 AM |
Mach 5 II or Kompakt 2 ? | Kurtstudio | Pro Tools TDM Systems (Mac) | 1 | 04-20-2005 12:49 AM |
Kompakt vs Mach 5 | Ray Lyon | Pro Tools TDM Systems (Mac) | 25 | 03-13-2005 11:08 AM |
EWQL Silver Symphony - Kompakt Crashes PT | Howardk | Pro Tools TDM Systems (Mac) | 11 | 01-24-2005 02:02 AM |
KOMPAKT | audiocase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-25-2003 09:12 AM |
