mbox 2 pro with fw800
I have gone through all the posts and still haven't found exact answer for this.
I have the new macbook pro with a fw800 port. I have a mbox 2 pro with fw400 ports. I want to record some music. How is it possible? any issues? What do I need to buy to connect these two? Thanks a tonne!.. I have been looking for an answer for past 3 months. C |
Re: mbox 2 pro with fw800
any person replying with experience would be much appreciated.
You can:
1) get a 800 to 400 firewire cable and daisy chain your hard drive and interface or 2) buy an expresscard and separate the interface and hd on different busses. Interface on expresscard, hd on MBP or vice versa. Either way, you'll need a fw800 to 400 cable if you only have 400 speed drives. If you connect the interface to the expresscard, you'll need the power adapter as the expresscards don't provide bus power without an optional adapter. J |
cool.. so I don't have to throw away fw400 items.. :)
any recommendations on which cables or expresscard to buy? Thanks a lot! |
siig makes a good fw card.
http://eshop.macsales.com/item/SIIG/NNEC2012S1/ i have heard that trying use the mbox2pro with fw800 is bad juju.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
Agreed on the siig card, that is the one I have. As far as a good cable, I like the Belkin one I got at the apple store, not cheap but works well.
As far as mbox2 pro with 800, I think that is when using the interface along with a 800 speed hard drive off the same bus. I think that as long as they are on separate busses it should be ok. J |
Yep but what should we do? apple became stubborn.. I also have a FW400 camera..
ok seems like belkin's out of stock.. oh me!
i had a different issue with an external but digi tech and others input may help here....http://duc.digidesign.com/showthread.php?t=226429
http://duc.digidesign.com/showthread.php?t=226305 http://duc.digidesign.com/showthread.php?t=226286 |
Can anybody confirm that?
http://felixrost.de |
New FW800 Grounded MBox coming??? | 7thheaven | Pro Tools M-Powered (Mac) | 2 | 09-03-2012 05:08 AM |
protools 10+MBOX 2 PRO+FW800+10.7 | barlevy | macOS | 2 | 08-15-2012 10:40 PM |
protools 9+MBOX 2 PRO+FW800+10.7 | barlevy | macOS | 1 | 08-15-2012 09:24 AM |
FW800 and Mbox 2 Pro | Barry Johns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 04-26-2009 09:36 AM |
Mbox 2 Pro & FW800 | MatthieuH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 10-22-2008 10:18 AM |
