Old 01-02-2021, 05:07 PM
[email protected] rpostlethwaite@neo.rr.com is offline
Default No Hardware Detected
I picked up a M-Audio Oxygen Pro 61 and it comes with Pro Tools First downloaded it when I open it up its start loading pluggins ect than I get a message no hardware found please connect your hardware device and turn it on and hit ok, I hit ok but same message pops up My Controller is plugged in and on.
Set to control Pro Tools and Windows as manual says. But I think Keyboard controller is not a hardware device. HP Laptop running Windows 10.
Any thoughts Thanks
Old 01-02-2021, 07:52 PM
Ben Jenssen's Avatar
Default Re: No Hardware Detected
The MAudio you have is a midi keyboard controller. It's used to trigger sounds in virtual instruments and apps.
What you need (the "hardware not detected") is what's commonly referred to as a "audio interface" that connects to the PC and handles the input and output of audio and the analog/digital conversion, and it's where you plug in your headphones and monitors. Like, I use the Focusrite Scarlett 2i2, and I can recommend it.
Old 01-03-2021, 09:04 AM
Southsidemusic's Avatar
Or if money is tight just download www.asio4all.com
It will use your onboard audio card and work as a virtual interface. This is NOT a replacement by any means as it usually sux but can be used until you buy a real interface. Let us know how you get on.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-04-2021, 10:13 AM
Thanks I am planning on getting an interface in near future
Mbox 2 PRO: No hardware detected adafrank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-12-2012 05:17 PM
No Hardware Detected JimIQMax General Discussion 0 02-21-2007 06:55 AM
MBOX2 PRO HARDWARE NOT DETECTED TIML 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-07-2006 09:37 AM
Hardware not detected reverenddoctord Pro Tools M-Powered (Win) 3 02-18-2006 06:17 AM
no hardware detected??? epiphany 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-20-2004 11:11 AM
