Clip dragging bug
This is very odd: when I try to drag some clip from one track to another it affects other clip strange behaviour.
It creates a very long fade even though the file is not long enough for that! The other clip is a different file not related to the dragged one. PT HD 2018.3 Anyone saw it? I can reproduce it 100%. Please see the video: https://youtu.be/F0aW455JFIA
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 Last edited by mgoorevich; 03-15-2018 at 12:11 PM. |
Re: Clip dragging bug
Not seeing it here. I'm also on 2018.3. Is there a broken clip group in the edit window? Does it happen if you disable Layered Editing?
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
The only work around is to make a Clip Group from selected regions I am trying to drag on the video. Or fully delete all the fades and crossfades inside of this selection...which is not a solution.
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
Clip dragging bug
Definitely seeing it here. I have not been able to establish what makes it happen.
It happens to me during reconforms. Turning layered editing on seems to make it work correctly. |
I am getting sick with this bug. Is it only me who is experiencing it?
It happens to me so often but with random clips. Now I saw an AS processing behaviour (also happens with a consolidate clip Shift+alt+3) https://youtu.be/pzfSVYQq7WA
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 Last edited by mgoorevich; 04-18-2018 at 10:05 AM. |
This is the video of the bug:
Dragging a Clip to New Track | adam79 | Pro Tools 12 | 10 | 01-20-2018 02:45 PM |
Pro Tools Quits unexpectedly after dragging a clip to the timeline | Inglesworth | Pro Tools 12 | 1 | 03-23-2017 06:09 AM |
Clip Dragging Issue | Porky | Pro Tools 12 | 6 | 12-07-2016 08:08 AM |
Dragging Clips from Clip window - ALWAYS Vertical sort!? | davedotpez | Post - Surround - Video | 2 | 05-20-2015 07:24 PM |
10.3.8-When vertically dragging a clip that shares a crossfade... STILL DOESN'T WORK | simonchase | Pro Tools 10 | 0 | 01-01-2014 02:14 PM |
