hardware connection error please help
I keep getting this error when trying to connect either a Command 8 control surface or a Novation midi keyboard with Automap (separately not at same time, both use USB). They seem to clash with my MBox Pro in some way. Anybody can help please?
After I setup the hardware in midi controllers and ok it, the error message pops up and reads this exactly: "The installed version of the controller personality "MBox 3" is incompatible with this version of Pro Tools. Pro Tools v11 Windows 7 64bit Ultimate |
Re: hardware connection error please help
Hi few things to try !
Delete databases and preferences http://avid.force.com/pkb/articles/e...ow_to/en378347 Check for other audio aplication installed if any that can see and use the controller or mbox. Also the ones running at background and if windows is using the mbox as default playback device. And last reinstall PT and Eucon again. Hope this helps you ! Sent from my SM-G973U using Tapatalk
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Thank you for your reply.
I think that may have solved it by deleting all the preferences. I just need to ensure my plugins are functioning again and I think the problem will be solved. Thank you very much for you help. |
Hardware synths and effect boxes (connection) | typhy | Pro Tools 12 | 1 | 02-26-2016 03:42 PM |
Error message: lost connection to hardware? | bifbangpow | Pro Tools 11 | 2 | 11-03-2014 12:02 PM |
Edit session without connection to Hardware / 003 | BradyP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-10-2007 12:17 PM |
002Rack Hardware connection Problems? TRY THIS! | Stephen1969 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-11-2005 09:34 PM |
Protools 002r / losing connection with hardware | ABC123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-11-2004 03:45 AM |
