MBox 3 error/warning "Controller Personality?"
Wow...what the hell is this warning that comes up when PTLE 8.05 loads with an MBox 3? I did not get it when I had 8.04. Program still opens after I hit "OK"
"Error occurred while trying to load the controller personality "MBox 3". |
Re: MBox 3 error/warning "Controller Personality?"
I searched and found a post about a eucon error like this and it said to delete things in the Preference folder...not sure what I would delete as I do not see controller or personality in there....
I trashed all the Preferences and that did not work. I am hoping Tech Support sees this - I have not seen a post about this happening with MBox 3 and 8.05.
Deleted and then restored 8.05. Same problem. If I don't hear from Avid Support I guess I will try to go back to 8.04
Nobody else is having this problem? Tech support, please advise.
I resolved this issue by going back to PTLE 8.04. Still cannot get a Hardware... dialog box to come up under the Setup Window. I reallay do not want to have to take the MBox 3 back to the store and go back to using my Digi002 or MBox 1.
I'm having the exact same issue, running on OSX 10.5.8.
Does anyone have a fix for this beyond going back to 8.0.4? |
I have the same problem and have notified Sweetwater support and Avid. It's been noted and verified on Sweetwater's end - was able to reproduce the same issue after upgrading to 8.0.5. I'm just doing without using the hardware setup for now.
Yes - 8.0.4 worked perfectly. I believe it's a conflict between PT and Mac OSX - I wouldn't go taking the Mbox back. I am waiting to see if there is going to be an update to 8.0.5
Yes, I was running 8.04 again but went back to 8.05 and "can't find controller personality" is back.
PT10/Digi 003 - Error occurred while trying to load the controller personality "003" | J-Xile | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-14-2015 08:36 PM |
controller personality "EUCON" incompatible | Pz5 | Artist Series | 8 | 06-04-2013 11:39 AM |
"Error configuring CNTRL|24 Personality" in Pro Tools 10 with Control|24 | jeff markham | ICON & C|24 | 2 | 05-26-2013 10:56 PM |
2 Problems after Upgrade PT9 to PT10: "Controller-Personality MBox3" and "MP3.dll" | Eviltubbie | Windows | 5 | 07-03-2012 10:39 AM |
Error occured while trying to load the controller personality "HUI" | speng | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-26-2009 11:21 AM |
