Old 09-14-2012, 10:16 PM
Swarf Swarf is offline
Default Burst of noise (not necessarily white noise) at the end of clips
Getting a huge burst of noise at the end of almost every audio clip I record. No waves plugins present in the session.
I have a MacBook Pro FW800->LaCie external drive which is sending out of the 2nd FW800 port to a FW800 to FW400 converter which is then being sent to a DIGI002r.
I have a hunch that the daisy chaining might be causing the problem. Help?
MacBook Pro 2012 8GB ram
LaCie External
PT 10.2
DIGI002r
Old 09-15-2012, 06:22 AM
Sparky1 Sparky1 is offline
Default Re: Burst of noise (not necessarily white noise) at the end of clips
LaCie External
PT 10.2
DIGI002r
Have you tried having fewer things in your daisy chain to see if the problem goes away?
Sparky
Old 09-15-2012, 10:52 AM
Went strait into the FW400 port with the 002 (assuming that gets linked to the 800 ports?). Also just got PT 10.3.
Haven't had time to run a session yet ; ) but I will post results once I do.
Old 09-16-2012, 03:28 AM
Erik318 Erik318 is offline
I'm having the exact same problem with Pro Tools 10.2. I'm running Windows 7 though and using a Focusrite Liquid Saffire 56 firewire interface. Every single clip I record has about half a second of noise at the end of the clip. I've been assuming it's a bug since I never experienced it before in any other version of PT. It is kind of annoying, and I really hope it has been fixed in 10.3. But I am reluctant to do the update since 10.2 is really stable for me and I don't want to jinx it :)
Old 09-16-2012, 05:58 AM
jryser's Avatar
jryser jryser is offline
Default
Does the LaCie have Oxford chips? The only time I have ever experienced this issue was when my buddy connected his OWC external drive to my rig. His drive did not have that chip. I have used Glyph drives from day one and have not had the issue.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 09-16-2012, 08:03 AM
lancemcv's Avatar
lancemcv lancemcv is offline
I have the same issue and record on my internal dedicated for audio sata drive, turning your delay compensation on and set to short seems to get rid of the problem. There are other posts aboutths issue.
Old 09-16-2012, 12:18 PM
Ah good suggestion, I'll have to try that. Couldn't find any other threads about quite the same thing. DTP seems to suggest that the fault is with Waves for a lot of white noise threads.
Not sure, will have to look. Just bought a OWC Mercury yesterday though... lol.
Old 09-17-2012, 08:50 PM
Just installed 10.3. Running fine so far, except the noise is still happening at the end of every clip. Turning Delay Compensation on does seem to get rid of it, but that's obviously a bad workaround that uses CPU.
Anything else? Fix coming?
Old 09-19-2012, 10:20 AM
bz lewis bz lewis is offline
I often get a "pop" sound when I'm using the Aphex Aural Exciter, so for me it's a plug-in issue. It only happens on bounces or when I do any signal routing in the Pro Tools mixer, so my regions/clips are fine.
check out studio 132 at www.studio132.com
Old 09-20-2012, 08:55 AM
ArKay99 ArKay99 is offline
more info and misery loving company here --> Loud explosion sound is back.
There is someone in the thread that gets your're problem too. I also get it along with the added bonus of an occasional nuclear test.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2.
LOUD white noise BURST after bouncing. 10.2 DJ Hellfire Pro Tools 10 55 02-23-2014 08:24 PM
white noise/sttic burst sounds need help please Q-BALL Pro Tools SE and Essential (Win) 1 08-01-2011 03:23 PM
White noise burst every 12 seconds. SixChurchStreet macOS 14 02-13-2011 08:11 AM
White noise burst on a track. Spyrojoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-14-2006 09:45 AM
Bounce To Disk- White Noise Burst Merle Mayhem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-09-2002 10:08 AM
