Old 06-19-2001, 09:59 AM
thopman thopman is offline
Default MIDI Clock vs. MIDI Time Code
Could someone please explain the diff in laymans terms, and explain which LE uses (or if it uses both).
My keyboards seem to want MIDI Clock in order to sync their onboard arpeggiators/sequencers, but I'm not sure how (or if) LE can output this, etc.
Thanks.
Old 06-19-2001, 05:31 PM
Lawrence Arps Lawrence Arps is offline
Default Re: MIDI Clock vs. MIDI Time Code
OK lets see how my memory is...
MIDI clock is a tempo referenced signal at 24 pulses per quarternote. It includes start, stop, continue. Use this for Drum Machines etc.
MIDI time code is a scaled down version of SMPTE time code that runs over MIDI cables instead of audio. It is Time specific not tempo. Good for linking recorders etc.
Note. If two devices are synced via MIDI clock they will both run at the tempo of the master. If they are synced with MTC there is no tempo link.
Judgeing from the statements in your post I think that MIDI clock is what you would be best to use. And yes I believe that 001 transmits this (but I havent checked)
Hope this helps
null
Lawrence
Old 06-20-2001, 05:01 AM
sandman sandman is offline
you have it in PT , i use it with my 303 & the prophecy , its working quite well
minus the gap it gets when your on a loop . . .then it gets out of sync
go to midi menu & choose midi beat clock ( i think ) choose your midi output and check the active box
good luck
Oh, it gives off an orange cloud of light, that just flows right out over the sea... wow!
Pro Tools Slaved by Midi Time Code or Midi Beat Clock DarylBham MIDI 5 06-14-2009 01:55 PM
Midi Time Code (MTC), or Midi Beat Clock David Lawler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-22-2005 09:22 PM
is there latency when using midi time code or midi clock(im still new at this) Cali Hendrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-15-2003 10:18 AM
is there latency using midi time code or midi clock(im new) Cali Hendrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-13-2003 04:50 PM
is there latency using midi time code or midi clock(im new) Cali Hendrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-13-2003 02:32 PM
