Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 08-20-2021, 02:34 AM
Selle Sellink's Avatar
Selle Sellink Selle Sellink is offline
Default Empty Offline Bounced Files
I'm having this issue with with a current PT session. Bouncing in real time works fine. But once I turn to offline I receive an empty audio track.
My Routing works fine otherwise I wouldn't get any audio when bouncing in real time either.
I tried importing all tracks in a new session since I thought the session might be faulty but no luck there either.
I've had similar issues in the past but this has always been fixed by making Sound Miner / RX Monitor or other iZotope plugin's inactive. No Luck this time.
I'm on:
MacOS Mojave 10.14.6
Pro Tools Ultimate 2020.12.0
Old 12-16-2022, 04:03 PM
Megalobass Megalobass is offline
Default Re: Empty Offline Bounced Files
I had the same problem problem with Pro Tools 2022.10 trying to bounced some wav files.
I think the problem is in the name of the bounced file. If you use some special character like «*é*» by instance the file is empty. If you just use the standard character it works. In my case it solves the problem.
Old 12-18-2022, 01:12 PM
Hmmm, can we assume no hardware inserts are in use? As an experiment, what happens if you off-line commit some tracks? Is it only this one session?(if it is, then dig into what's different from other sessions)
Old 12-18-2022, 01:35 PM
^^^ Good question/suggestions, yes sometime folks just forget they have a hardware insert in a session.
What are the tracks? All Audio? AUX input? Routing though sends? Is LLM enabled?
Can you share an example session online that does not work?
Old 01-13-2023, 11:28 AM
Default Re: Verifpro.net - paypal, ebay, banks, crypto, docs and more!
Originally Posted by Rokit88 View Post
Verifpro.net - paypal, ebay, stripe, banks, crypto, docs and more!
Follow channel (URL removed by JoelG) to get more info
This is a clear violation of DUC rules and you will be banished
Old 01-13-2023, 11:29 AM
That account likely has been hacked, already been reported.
Project list is empty? Where are my files? zhacarys Pro Tools 12 0 08-09-2019 09:58 AM
Pro Tools 11-.zip files empty on download tdennett Windows 7 12-27-2014 03:27 PM
Empty bounced-to-disk file Lalaman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-30-2003 08:30 AM
Bounced segments offline. Kjetil Post - Surround - Video 2 05-30-2001 08:42 AM
PT writing empty audio files to 2nd I/O posey Pro Tools TDM Systems (Mac) 1 01-06-2000 08:15 AM
